Before I tell you to spend a hundred bucks on a Carnetix CNX-P1900....
Laptop PSU
You could do this with your laptop psu.
However you will waste a lot more power.
Your laptop psu better be rated to 8 or 9 amps (I'm ballparking here).
Regulator
An LT1038 is rated to 10 amps.
But be ready to provide a good heat sink and mounting location cause it's gonna get hot!
http://www.datasheetcatalog.com/data...0/LT1038.shtml
I haven't worked with them but search the posts they have been mentioned often.
Startup/shutdown control
You could make your own, based on the accessory signal and relays.
I've got one setup that relies on the taillight to isolate or energize the pc.
When you add up all the work you will have to do and the lack of features to going this route you should really consider a good DC-DC regulated 12v supply.
LinkBack URL
About LinkBacks
