Results 1 to 9 of 9
Thread: not booting but rebooting instead
    Apr 2007
    i have install my car pc and when i switch it on it goes through the post test and tries to load windows but then decides to reboot and do it all again.
    i have tried several different things including different hard drives etc.
    any ideas?
    my system consists of:
    m2 atx ps
    atx mb
    amd athlon 1700
    radeon 9250
    thanks
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    have you try a different PSU?
    Maybe not enough power.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Apr 2007
    i dont have another power supply to try. if it wasn't enough power would it switch on at all or even try to boot?
    Sep 2003
    Beach City, Socal
    You don't have another PC at home? Use an AC PSU to test to see if the PC boot. That will rule out component failure.
    If it does, plug back the M1 and remove some of the none essential components like CD/DVD ROM, sound card, wifi, .... to see if it boot with the M1.
    If it does, start plug back one component at a time until it doesn't boot. Now you know what to do next.
    Apr 2007
    i tried an ac psu and it boots fine, removing non essential components made no difference. i can only assume the m2 isnt powerful enough.
    Elsewhere
    Your CPU draws either ~65w or ~50w, depending on the core. I'd find out what core your CPU is, as it makes an obviously huge difference in power draw.
    Granted, neither of those values are going to push you over the limits of the M2.
    Why that video card?
    3D video cards tend to be huge power hogs. As a general rule, the newer & more powerful the 3D chipset, the power it will suck away.
    I'm willing to bet that replacing the Radeon card with onboard video (if available) or another, lesser video card, your problems booting will all go away.
    I can't be 100% certainm, though. You could have a bad ground, a wiring problem that we're not aware of or some other issue. Buit I think the video card is a likely place to start.
    How about the Wiki?
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    My M2 does this occassionally with an SP13000 board
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    I have this same video card. Its PCI so i can add it to my Via Epia MII1200motherboard. I'm trying to find power requirements for it. I want to be able to play simple FPS games during lunch or traffic jams, Maybe quick shoot out at a stop light
    Guess I could get out some amp meters and run some tests with an AC power supply.
    Question is, Anyone know how much the 9250 128meg PCI video card consumes in power?
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Quote Originally Posted by timoteldr View Post
    thanks
    Try this first, put in windows cd and boot. When it says hit r for repair press r. When the prompt comes up, type chkdsk. You might also try sfc /scannow after that.
    Reboot and see if everything is ok. If not, try the sp repair routine...
    XP Repair
    1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
    2. When you see the "Welcome To Setup" screen, you will see the options below
    This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
    3. Press Enter to start the Windows Setup.
    do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console).
    4. Accept the License Agreement and Windows will search for existing Windows installations.
    5. Select the XP installation you want to repair from the list and press R to start the repair.
    6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
  1. Tutorial: Booting XP from a USB device...
    By mbkowns in forum WinNT Based
    Last Post: 03-05-2007, 09:51 PM
  2. computer keeps rebooting
    By NovaKane in forum WinNT Based
    Last Post: 02-08-2007, 10:57 AM
  3. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 07:39 PM
  4. Booting Issues
    By camaro of solar in forum General Hardware Discussion
    Last Post: 01-08-2007, 04:05 AM
  5. Rebooting when loading WinXP
    By DtM in forum Power Supplies
    Last Post: 10-04-2005, 03:05 AM
