Results 1 to 2 of 2
Thread: Variable Voltage 5A Regulator
    Dec 1999
    Buena Park, CA
    I found this on while doing a google search. The link includes a diagram for a 5A regulator which I am assuming simply takes the input voltage and passes it through while regulating the current. My electronics background isn't strong enough to properly interpret the data sheet. Any thoughts?
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    A 5A current regulator will attempt adjust the output voltage so that the load takes 5A (obviously, given that it is a linear regulator, it can't make the output voltage larger than the input voltage).
    A 5A regulator (which I could find a circuit for in the datasheet, but it trivial to do - that's exactly what the chip does) is a voltage regulator that is capable of regulating up to 5A current draw.
    I like the way the 10A regulator circuit uses an opamp as a comparator with current sense resistors to balance the current load between the two regulator chips. Very neat...!
