Results 1 to 4 of 4
Thread: Will an M2-ATX work?
    Constant Bitrate stangg172006's Avatar
    Jan 2007
    Morton Grove, IL (Northside Chicago)
    Hey guys, heres my set up
    Abit socket 775 micro ATX board
    Celeron D 3.3ghz processor
    One stick of 256 ram
    heat sink with fan
    case fan
    USb from monitor
    GPS USB receiver
    and one USB keyboard
    thats the list of everything that will constantly be plugged in.
    ive calculated the power on an online calculator and its giving me like 200+watts.
    am i doing something wrong? can an M2-ATX work? if not, where can i find a higher powered PSU with intelligent turn on/shut off? Thanks
    '08 VW Rabbit S 2.5
    Carputer Progress:
    Design:[][][][][][][][][][][][][][][][][][] 100%
    Fabrication:[][][][][][][][][][][][][][][][][][]100%
    Installation:[][][][][][][][][][][][][][][][][][][][][][][][][] 80%
    In trouble...
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    What's the power rating of your CPU?
    I'm running basically the same setup except with a 2Ghz regular celeron, which i think is '65W'. Also got my 16W screen plugged in. M2 ATX working fine with me. Haven't bothered to check to load yet but I'm pretty sure I'm under 160w.......
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    if you can go with less clocking values (detune your processor), you might be able to do it
    i don't recommend if you want to take an advantage using usb devices, they will simply not operate
    R. T. F. M
    Jan 2007
    Quote Originally Posted by Nerd2 View Post
    well this is what wiki says for a Celeron D 356, 65 W (D0), 86 W (C1).
    http://en.wikipedia.org/wiki/List_of...22_.2865_nm.29
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
  1. Stupid M2 ATX !!
    By rxh81 in forum Power Supplies
    Last Post: 03-21-2007, 01:56 PM
  2. Would m2 work?
    By Ravin13 in forum Power Supplies
    Last Post: 02-11-2006, 01:07 PM
  3. Wtb: M2 Atx
    By EsKALad in forum Classified Archive
    Last Post: 01-03-2006, 09:59 AM
  4. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
  5. Will an ITPS work with an ATX motherboard
    By NightHunter in forum Power Supplies
    Last Post: 02-24-2004, 03:33 PM
