Results 1 to 3 of 3
Thread: inverter input power?
    Constant Bitrate archaic0's Avatar
    Jan 2007
    McAlester, OK
    I have my carPC currently hooked up via an inverter and have a power controller coming to do the PC turn on/off. I chose to go this way because the DC-DC PSUs I've tried aren't up to the task of running a full blown Athlon 3000 CPU.
    My issue is that if my car isn't running then the power inverter only gets 12 volts or a little under (like 11.8) and it starts beeping. I'll run like that for hours as I found out by accident one time, but I don't like the situation.
    I'd like to be able to leave the PC running while the car isn't, but that beeping is annoying. I thought about just finding and disabling the actual beeper, but is there some way to stabalize the incoming voltage?
    I don't know just how low I can get on the incoming side though with this inverter. Anyone out there know of an inverter made to work with as low as 8 volts maybe? I would bet that that's too low to start my car with, but just as an example...
    Jan 2007
    New Jersey
    Quote Originally Posted by archaic0 View Post
    I know its a bit off topic, but are you getting any noise or other weird problems from the inverter. I finally have all the parts for my CarPC and am ready to install. Just wanna know what mishaps ill run into after all is done.
    BTW, I think if you run the inverter for too long with the car off, it'll drain the battery, giving you problems when its time to start the car.
    Jan 2007
    McAlester, OK
    I had some noise in the audio signal at first but a ground loop filter fixed that right up. I haven't had anything specific happen that was caused by the inverter.
    Yeah, if you run it too long then you can't start the car, but my inverter wants 13.5 volts or it starts beeping. It'll beep as soon as I shut the car off sometimes. It's a low power warning, but it's factory say way to high for my purposes.
  1. Question about inverter and normal pc power supply
    By bns2000 in forum Power Supplies
    Last Post: 10-16-2005, 04:49 AM
  2. power inverter power supply shutdown problem
    By launter in forum Power Supplies
    Last Post: 09-21-2005, 12:12 PM
  3. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  4. power issues, will an inverter regulate?
    By blustreak in forum Power Supplies
    Last Post: 01-23-2005, 03:39 PM
  5. Power inverter on/off switch question
    By Skipjacks in forum Power Supplies
    Last Post: 01-22-2005, 01:33 PM
