Results 1 to 10 of 10
Thread: Dead M2-ATX on XBox
    Feb 2007
    Dead M2-ATX on XBox
    Hello
    I used a M2-ATX to power the XBOX in my car (had to replace the original PSU und make an own adapter cable as described in the forum). It worked for about 100 hours, but yesterday, it looks like the M2-ATX died.
    I'm not very sure what it is:
    - There is no visible "burn mark", but it smelled like a part burnt out
    - J1 Battery+ and J4 Battery- seem to be shortened now to 0Ohms (even without power)
    - Q9 MOSFET FDS6680A is getting very hot now with power
    Is there any general hint to find the burned part? Any tipps & tricks? There is probably no schematic avaiable of the M2-ATX, right?
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    the wires aren't in the same pattern on the PSU socket of an XBOX mobo to what they are in an ATX PC
    I know this cause I tried powering an xbox with a PC PSU to test it, and it never worked again, and the psu was dead too Im affraid you fried it
    There is a way of changing the wires round though, read it somewhere on an xbox forum ages ago
    Feb 2007
    Hello ShawJohn,
    as i described above, i have made a correct and working adapter cable. It worked for five or so.
    Low Bitrate MibMib's Avatar
    Jan 2006
    KyrGyzstan
    Hi
    1.Could you make a high pesolution pix of top and bottom of m2 ?
    2.Does yours xbox work from it's own or another psu now ?
    400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
    Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
    Aug 2004
    On the edge!
    sounds like the xbox has overloaded the M2
    Feb 2007
    Yes, might be the 5V rail. The problem is that i had to connect the 5V STDBY from the M2-ATX to the 5V from the XBOX because the standby function. (see attached pictures)
    Anyone can give me an answer what happens if I wire 5V STDBY and 5VDC from M2-ATX together?
    Aug 2004
    On the edge!
    Boom !!!
    Only kidding
    I don't know Someone else might...
    DIGItonium
    Guest
    If the battery terminals are shorted, then the M2 ATX is definitely toasted. All is not lost, however. The FET burning up is probably faulty because it is probably shorted to ground. See if the "drain" pin is shorted to ground. Remove the part and see if the short goes away.
    Feb 2007
    Ok, had to send in my burned M2-ATX and got a brand new M2-ATX. Now again, everything is working fine, as it did before i had the problem. I don't know what it was, might be really one the "usual" M2-ATX problems and is not X-Box related. Btw, i measured that the XBOX needs only about 50W in music and video play mode on XMBC.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by ghujdal View Post
    how old was your m2 when u sent it back? i have this EXACT same problem with mine now on my car pc but i've had it for just over a year and wonder if they still would honor the warranty.
    Live mp3Car Facebook Chat
  1. M2-ATX Problem - Fan runs but does not boot !
    By Autonator in forum Power Supplies
    Last Post: 11-14-2006, 06:22 AM
  2. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
  3. Dead ATX PSU(s)
    By kefka_killer in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:13 PM
