Where did you tap into? Sounds like you already are tapped into the door locks. Might want to find another wire to connect to. Problem with using the locks is most cars now lock when you put the car in gear and unlocks when the car is in park. You would turn on the pc when you unlock to get in, as soon as you go to drive off car locks doors and shuts off pc. Then put it in park, turns it back on, and so forth.
LinkBack URL
About LinkBacks
