Moved out of newbie forum topic hoping to get an answer from some veterans here.
Thanks again.
How does one connect an 8awg to the awg(not sure what awg the wire is on a carnetix unit)? Do you just solder it on or twist the ends? My setup is 4awg from the battery to the back of my car through a fuse and to a distribution block. How would I go upon connecting the two?
Thanks ahead of time
"The text that you have entered is too long (12638 characters). Please shorten it to 10000 characters long."
Dam it!
"The text that you have entered is too long (10418 characters). Please shorten it to 10000 characters long."
Thanks again.
Dam it!
For wire splices, the preferred method is soldering, then covering with heatshrink.
The secondary method is crimp connectors.
A "twist & tape" connection is fine for testing purposes, but it too fragile a connection for daily use in the car.
Remember that we're talking about more than just whether a bit of electronics will work. A short in your car can potentially cause a short, which could lead to your car not working, a fire, injury and/or death.
I don't tyhink you'd like to experience any of those.
Thanks so there shouldn't be a problem connecting an 8gauge wire straight to the carntix p1900 wire with like 14,16 gauge?
Dam it!
Thanks again, your tacomas coming along nicely.
Dam it!
