Results 1 to 10 of 11
Thread: Dell inspiron battery?
    May 2007
    I am thinking of buying the Carnetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator for my dell inspiron 1100 laptop. The battery on my laptop is dead. I know its dead and the computer does work if i take my battery from my other laptop. If i hook the laptop to the carnetix which i know how to do. will the carnetix be able to turn the computer on? and will it stay on? Next question intails extending the wires from the screen. can it be done?
    May 2007
    Anyone? Will the carnetix bypass the main battery on my laptop?
    Elsewhere
    The carnetic provides power just like an AC power adapter would. So if the laptop will run with an AC power adapter, then it will work with the Carnetix.
    How about the Wiki?
    Constant Bitrate mwmcginn's Avatar
    Dec 2006
    St Louis
    I would go with a kensington travel power supply, pretty cheap on ebay. I dont know that you will need to carnetix, but its your ride. How much is a new battery for that thing?
    Mike M
    2006 Accord VP Sedan
    My worklog
    http://www.mp3car.com/vbulletin/work...-dads-car.html
    Elsewhere
    Quote Originally Posted by mwmcginn View Post
    The carnetix has a startup/shutdown controller built in. That will allow the ignion to control startup/shutdown of the PC.
    How about the Wiki?
    May 2007
    A new battery will cost me 160 without shipping. And the computer doesn't power on even when the Ac adapter is hooked up. When i put my battery from my other dell laptop in it, it powers up. I want to know if there is a way to bypass the battery so i don't have to buy a new battery for a computer that is 4 years old.
    May 2007
    If that doesn't work. then can i use the mother board out of my desktop and use the hard drive and memory from my laptop. will the hard drive and memory be compatible with a desktop mother board?
    May 2007
    Because a new battery will be 160 and the lap top needs a new CD/DVD drive thats another 70.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by LivinLarge View Post
    Hard drive yes, RAM no. If you have to ask this, then you might need to read up a bit on computers. A CarPC is cool, but when you get a BSOD or something, something tells me you wont be able to fix it by yourself.
    So either you need a lot of money to pay people to fix the problems, or a little bit more knowledge of computers.
    And you dont need a new battery for a laptop that you will be powering off of a Carnetix. And why would you need an optical drive either? Store everything on the HD and be done with it.
    1.9in x 2.9in -- 47mm x 73mm
    May 2007
    Thanks 2k1Toaster. So know that i know that the carnetix will power my computer without a working battery i will order it. All use search to figure out how to hook everything up. I already have an idea of how to but i need to make sure. escpecailly the startup/shutdown function
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 11:10 AM
  2. FS: Dell laptop power supplies
    By wrxmaster in forum Classified Archive
    Last Post: 08-10-2006, 09:41 PM
  3. FS: Dell Inspiron 9100 Laptop - Freshly formatted $1000
    By blumatrix03 in forum Classified Archive
    Last Post: 11-28-2005, 11:34 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
