You should be fine.
I am sure it's ok and I read the FAQ on connecting everything but there was so much more misinformation on there that I just wanted to double check.
While I need to run a new power wire directly from my battery, it should be ok to use the original ignition switch from the factory wiring harness since it doesn't draw power but uses a small current to know that it should be on correct?
