Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: beeping thats like beeeeeep
    Feb 2006
    ok i have a power inverter thats 400watts and when im sitting in the car nto moving and i turn my wheel all the way to one direction it just goes BEEEEEEEEEEEEEEEEEEEEEEP and i hate it... is this cuz of power loss? i have a redtop optima battery. would it be better if i hard wired the inverter or just directly connected it to the battery? Thank you
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Does it make the beep noise as you shut it off? If it does, ot's a low battery warning.
    Sounds like you're pinching a wire somewhere when you turn the wheel, as unlikely as that sounds. Or you're putting a draw on the electrical system that is causing the voltage to drop off....
    Leonardo Da Vinci
    Feb 2006
    it makes a tiny beep when i turn it off but that seems normal.
    hmmmm maybe I should try hard wiring it.
    Quote Originally Posted by greatwhite View Post
    Feb 2006
    would it help it took pics on how these things were connected?
    Mar 2006
    Colorado, but Canadian!
    pics always help.
    And "hardwire" and "directly connect to the battery" are the same. Are you sayng you just plugged it into the cigarette lighter adapter?
    And does it only happen when you turn all the way to the left or right with the wheel, or any other times too?
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2006
    yes i have the inverter plugged into the cigarette lighter. but me check..OK argh
    I turned the inverter on turned my wheel all the way to the left nothing it was fine
    then turend wheel alll the way to the right and nothing... then moved and it did nothing it was fine..
    but do i have to turn on the computer when doing this or not?
    Quote Originally Posted by 2k1Toaster View Post
    pics always help.
    Low Bitrate MibMib's Avatar
    Jan 2006
    KyrGyzstan
    Wow ........ are you crazy man? it's a very bad idea - to use cigarette lighter with powerfull invereter - it's dangerous !!!
    Simply - connect it directly to the battery, i think it will stop beeeeeeeping Good Luck
    400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
    Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
    Feb 2006
    hm................ ok then... ill just... hard wire it. i guess like take the inverter and hook it up directly to the battery wouldnt be better?
    ;;feels like homer when he tried to cook breakfest for Mr.Burns::: and everything caught on fire;; hmmm
    Quote Originally Posted by MibMib View Post
    Wow ........ are you crazy ? it's a very bad idea - to use cigarette lighter with powerfull invereter - i's dangerous !!!
    Feb 2006
    cuz i have been meaning to put pics of my Carputer ))
    Feb 2006
    does anyone have any more suggestions?
  1. Compaq Presario SR1000 beeping
    By Gunmaster in forum General Hardware Discussion
    Last Post: 07-27-2009, 02:23 PM
  2. beeping Prob, help me....
    By azhar5i in forum General Hardware Discussion
    Last Post: 01-11-2007, 12:37 AM
  3. Replies: 9
    Last Post: 01-12-2006, 04:52 AM
  4. Replies: 0
    Last Post: 01-10-2006, 09:58 PM
  5. Beeping Noise from motherboard
    By SurfinCajun in forum General Hardware Discussion
    Last Post: 11-09-2005, 12:48 PM
