Results 1 to 8 of 8
Thread: 24 pin motherboard to a 20 pin power supply
    Jan 2006
    Hello, I just purchased a new motherboard but noticed that it has a 24 pin power slot. I was planning on powering it with my dsatx 20 pin power supply. It this possible? What are the extra 4 pins on the motherboard for? I saw an adapter that allows me to connect a 20 to 24 pin
    http://www.radioshack.com/product/in...entPage=family
    Do I really need this adapter or can i just plug in the 20 pin into the 24 pin and just leave the other 4 pins untouched? And what exactly is the other 4 pins for? I was thinking power for a much faster and power hungry processor?
    Low Bitrate MibMib's Avatar
    Jan 2006
    KyrGyzstan
    In Most times you can use it - simply look at connectors - you 'll see that 20pin fully identical to part of 24-pin - simply connect it with right direction and position. Many motherboards works great with it. You can leave the other 4 pins untouched.
    4 extra contact uses by very powerfull systems .....
    If wires from connector don't takes warm-use it greatly
    I also wrote about this problem in user guide of mine Pilot psu with pics of pinouts of connectors.
    400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
    Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
    Jan 2006
    Ok, i just did some research and I found out some things... One of the threads here suggests that i can plug in the 20 pin molex into the 24 pin motherboard and just have 4 holes empty and that it works fine but I have a question. The 24 pin molex has 4 extra pins, pin 11 (+12v) , 13 (+3.3v), 21 (+5v), 24 (ground). But on the 20 pin molex, pin 11 is +3.3, 13 is ground, so if i were to plug this into the motherboard, it would get the wrong kind of voltage. So i dont understand why is it that some people say its ok to just plug in the 20 pin into the 24 pin motherboard when its going to be feeding the wrong pins into the board or am i in the wrong here. Can someone please clarify this? thanks
    here is the links for the pin out
    24 Pin
    20 Pin
    Jan 2006
    KyrGyzstan
    You are wrong with pin numbers - look again at your links - it's ok!
    pin 11 of 20- pin connector is same the pin13 of 24-pin connector.
    Simply download mine user guide http://downloads.pilotpowersupply.com (160 Kb)
    And look at Figure 3. of this user guide - I think it will be more clearly for you.
    Cheers.
    Jan 2006
    So according to your pdf, i do not need the adapter and I could simply connect the 20 molex into the 24 pin motherboard connection. Ok, that helps thanks. I could save myself those 10 dollars for the adapter...
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    Some will work and some will not. Trial and error i think.
    But the extra 4 pins are for additional power or PCI-e i believe..
    10 acura TL tech
    10 BMW S1000RR
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by john05srt4 View Post
    My Jetway 2ghz works fine with only the 20 pin connector plugged into a 24 pin socket.
    Jan 2006
    KyrGyzstan
    Just try it , if it will not work - then by an adaptor, and if you can , please post here results and motherboard's model also.
    I am great wondering about your adapter's price
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. connecting a PSU to a board which doesn't a have 20 pin connector
    By al_kaholik in forum General Hardware Discussion
    Last Post: 12-02-2006, 03:21 PM
  3. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
  4. power supply buzzing help thing i found... read if u have noise
    By TimW in forum General Hardware Discussion
    Last Post: 03-22-2000, 04:30 PM
  5. Pin outs for AT power supply
    By twins22 in forum General Hardware Discussion
    Last Post: 11-02-1999, 08:01 AM
