+ Reply to Thread
Results 1 to 10 of 20
Thread: My motherboard has a non standard 24 PIN power connector
    May 2007
    My computer is a HP Pavilion s7730 with a Asus MOCA-AR (OEM) motherboard (can't select it in the model list...). I need to use the computer in a car, so i need to adjust the power supply. For use in my car i will use:
    http://www.mini-box.com/M2-ATX-160w-...8&category=101
    The problem is that this device has a 20 pin, and the Asus MOCA-AR a 24 pin power connector. A normal adapter (from 20 to 24 pin) like this:
    http://www.tigerdirect.com/applicati...751&CatId=1107
    won't work, because the 24 pin connector is much too large for my motherboard. I have made a picture of the power connector from HP Pavilion power supply (black one) and my 20 PIN (white) connector.
    http://www.nb.nu/power%20atx24.jpg
    Any change to find an adapter for this (or make one by myself?)
    Kind regards,
    Marcel
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    The short answer is make it yourself or use a different MB.
    HP, Dell and others sometimes use non-standard PS parts. It may actually use different voltages and or pin outs.
    Be very careful as mixing up the wires can break your MB.
    Use a meter to measure the voltage of each wire before attempting to use an adapter or different PS.
    TruckinMP3
    Read the FAQ!
    Mar 2006
    Montreal
    you can still plug 24 pin power from psu to a 20 pin port, works on most motherboards ! just the 4 extra pins will OVERLAP the plug, if theres room on the edge, it'll work.
    Jun 2002
    Colorado
    Quote Originally Posted by tracker64 View Post
    This statement assumes the MB uses a standard pin out, this is not always true for Dell or HP.
    Use a meter to make sure before you let the smoke out.
    TruckinMP3
    Read the FAQ!
    May 2007
    Quote Originally Posted by TruckinMP3 View Post
    Thanks for your answers.. To buy a new motherboard. a jut bought this computer a few days ago:-(
    Ok, i'll make it myself and will measure before i act. But i still have to get the right connector (the black one). Does anyone of you recognize ths connector? It is much smaller then the regular 24 pin atx connectors....
    Marcel
    (if interested i can upload some imagesof my BMW E39 touring)
    May 2007
    I'm interested in your solution or what the pinout of the connector is.
    The tech at HP gave me the following for a 20 pin based on the motherboard, but I don't believe he knew what he was talking about:
    ATX Power Connector
    Pin Signal Name Pin Signal Name
    1 +3.3 V 11 +3.3 V
    2 +3.3 V 12 -12 V
    3 Ground 13 Ground
    4 +5 V 14 PW_ON
    5 Ground 15 Ground
    6 +5 V 16 Ground
    7 Ground 17 Ground
    8 PWRGD (Power Good) 18 -5 V
    9 +5 VSB (Standby for real-time clock) 19 +5 V
    10 +12 V 20 +5 V
    May 2007
    Quote Originally Posted by tony2socks View Post
    ATX Power Connector
    1 +3.3 V 11 +3.3 V
    2 +3.3 V 12 -12 V
    3 Ground 13 Ground
    4 +5 V 14 PW_ON
    5 Ground 15 Ground
    6 +5 V 16 Ground
    7 Ground 17 Ground
    10 +12 V 20 +5 V
    No, the motherboard as a 24 pin connector, which uses exactly the same pinout as ä regular connector.
    Anyway, i did loose my patience. I have cut the wires, and soldered it directly on a regular connector....
    kr,
    Marcel
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by dotinga00 View Post
    kr,
    Marcel
    So it really was a regular ATX connector, but they shrunk it down?
    1.9in x 2.9in -- 47mm x 73mm
    May 2007
    Quote Originally Posted by 2k1Toaster View Post
    Indeed......
    Ir was this connector
    http://www.molex.com/pdm_docs/sd/430252400_sd.pdf
    Marcel
    Sep 2007
    I have the same computer. You have a nano-atx motherboard. I'm setting my computer as we speak. Here's the link got the adapter. I still haven't ordered it but it should do the job.
    http://www.mini-box.com/Nano-Power-A...=8&category=13
+ Reply to Thread
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. 24 pin motherboard to a 20 pin power supply
    By jdiazj1 in forum Power Supplies
    Last Post: 05-16-2007, 09:15 PM
  3. headrest lcd s video connector pin out
    By hot_sedan in forum LCD/Display
    Last Post: 08-01-2006, 03:47 PM
  4. Replies: 8
    Last Post: 05-13-2006, 08:21 PM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
