Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Opus 250W not sending any voltage through remote lines
  1. #11
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Does sound like a faulty board then mate - have you visually 'inspected' it? Did you get it from a decent retailer? or a dodgy ebayer ?
  2. #12
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    Quote Originally Posted by Nerd2 View Post
    i bought it from here (mp3car.com)...i just want to make sure it is actually broken before i ask to RMA it.
    when i opened up the package, there was a jumper pin bent on it...but it wasnt touching another pin so i didnt think too much about it since in the wiring diagram, that pin is used for the 20second startup/shutdown and i wasnt going to use that...i am using the 10 second...
    what do you think?
    i bought it on March 24th 2007...
  3. #13
    Dec 2006
    Ahh you're allright, you bought it from a decent store, just RMA it. No probs.
    I mean, if you really can't be bothered, I'm sure you could probably invent something to do the job, but when it's supposed to be sorted by the PSU, you're just adding more complexity, more to go wrong in the future. I know it's annoying, but if I were you, i'd RMA it.
  4. #14
    Apr 2007
    on Earth
    Thanks dude...ill give MP3car a call tomorrow and get an RMA number...or whenever they are open again (its a holiday tomorrow)
    i probably shouldnt have delayed RMAing it anyways...the motherboard fried in my trunk and i had to RMA it to MSI...i have to wait 3 weeks for it...bastards...no immediate replacement like Newegg...
  5. #15
    Nov 2006
    did u get this fixed ?? i actually have same problem with my opus 250..
  6. #16
    Apr 2007
    on Earth
    no...i didnt get this fixed...i contacted mp3car about getting an RMA...havent been emailed the authorization # yet...
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
  7. #17
    Feb 2006
    How do you have the jumpers for the remote leads set? And how long have you waited for the remotes to go on? Another thing you should check is how much current you are actually drawing from them. These remotes cant support much current, I had that problem myself.
  8. #18
    Apr 2007
    on Earth
    i already sent the PSU in for RMA. i tested all jumper settings according to the downloadable user guide for the 250W PSU from the Opus webpage. there was absolutely 0 (zero) volts leaving the remote lines to turn anything on connected to the remote lines. its supposed to send 12V to the device its supposed to turn on.
    i waited at least an hour for it to turn on on one occasion. i was driving to work with no sound, and i was too lazy to get out and jump my amplifier from the power line to the remote input to "hotwire" my amp. that same day i took it to Best Buy and tested it with a multimeter and thats how i found out there was no current going through the remote lines...
    Subwoofer: removed
  9. #19
    Nov 2006
    i hav same problem.. never sent it back in for RMA since i stopped using hte remote leads, but i might..
  10. #20
    May 2005
    San Clemente, CA
    You wouldn’t get a reading, because it doesn’t send a constant signal. Otherwise it would be turning on and off!
    The M1/M2-ATX do the same thing. It’s not sending enough of a punch to work. Just hook it to a fuse and if you have problems with a pop, add a relay to introduce a delay.
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
  1. Opus 250W, but System not POSTING ???
    By CoupeE46 in forum General Hardware Discussion
    Last Post: 02-23-2007, 07:57 PM
  2. ordered opus 250w psu
    By ponch37300 in forum Power Supplies
    Last Post: 01-08-2007, 02:25 PM
  3. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
  4. FS: Opus 90watt with Remote Trigger
    By naevity in forum Classified Archive
    Last Post: 03-29-2004, 05:47 PM
  5. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
