Results 1 to 10 of 11
Thread: Interter-UPS-PC..anything missing?
    Jul 2006
    Exclamation Interter-UPS-PC..anything missing?
    I have a 300w ups with a max serge of 800w and a 500VA UPS - now how do i go about connecting it...
    CarBattery - -TANK CIRCUIT - - Aux Battery (UPS)
    now i attach a relay (please give me the schamatics and specs of the relay) so that when the car is off my aux battery is providing the back up...i would connect the (-) and (+) of the ups battery direct to the altinator through the tank circuit...so that it gets charged and kicks in when the car is cranking or i have the carputer turned on when the car is off....
    kindly help me - thanks guys!!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If I read you right, you trying to connect from the car's battery -> Inverter -> UPS -> AC-PSU -> Mobo. If that the case, before you going further, try to plug in the inverter and the UPS to see if the 2 working nicely in the car.
    UPS in known to NOT WORKING with sqarewave inverter.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by ankitgoenka View Post
    You have a lot of reading to do.... Good luck....
    TruckinMP3
    Read the FAQ!
    Jul 2006
    i know i am a complete newbie...can ne one please guide me - cuttin out queries...as to how to go abt the project...i have a inverter and usp and everythig else - please make things simple!
    Jun 2002
    Colorado
    The trouble is.... the path you picked is not simple. The parts you have probably will not work together. Re-read the post by MatrixPC.
    Then start reading the Power Supply section for a couple ideas on what to use for correct results.
    As it stands we could tell you and you would just argue that you already have the hardware for what you want.... and it will circle around making you upset and lead to flames.
    Please go read and get the right background.
    TruckinMP3
    Read the FAQ!
    Sep 2003
    Beach City, Socal
    To make it short. The UPS and inverter you have in your hand will NOT working together. Basically, you can only use the inverter.
    Read up the FAQ section regarding to power supply. To get more idea.
    You can use inverter, Tank circuit, 2ndary battery together but you can't use inverter (square wave) and UPS. Unless you pay for big $$$$ for a sinewave inverter.
    _
    Mar 2004
    Little Elm, Texas
    to all of them.
    Many times people come onto this forum trying to apply their computer knowledge to the car, without realizing that there are two different kinds of electricity (AC and DC). Generally, you cannot take ideas for AC and apply them to DC.
    I'll suggest what the others have suggested. You really need to read up on this stuff to learn that things are different between the car and the desk.
    There are specific products that exist to make a PC work in a car. People have developed them for a reason and they work.
    Good luck!
    Jan Bennett
    Jul 2006
    thank u so much...now that i have a brief idea - i wud use jus the inverter - connect it to a tank battery...and if i am wrong i am still going 2 do some reading on the forum...thanks a lot guys...
    Jul 2006
    Thumbs up
    I have been successful in testing my idea...
    battery (12v 7AH) inverter(300w max surge 800w) - usp (non smart ups - which i have modified - added a switch to turn off the annoying beep)
    when i power the ups thru the inverter its working on ac lines and as soon as i turn the inverter off - the ups kicks in....there is no power failure or pulse...
    thanks guys...UPS;s are not pure sine wave - but are quasi sinewave - which is good enough...
    thanks again!
    Nov 2007
    thanks again!
    nice to hear that but people here say the ups battery wont get charged by the squarewave inverter. how are your ups battery going with it?
    if the only issue is that the battery wont get charged, I am thinking of a circuit to charge the ups battery when engine in running, it might be messy but it will work. lets put aside the ROI for now
  1. ONINE PETITION: TomTom Navigator for PC
    By bLindmOnkey in forum GPS
    Last Post: 06-07-2007, 02:16 PM
  2. FS : Car PC Inc Cables (UK)
    By Maverick in forum Classified Archive
    Last Post: 03-13-2007, 09:34 AM
  3. Replies: 21
    Last Post: 07-22-2005, 02:35 PM
  4. In progress car PC install.
    By Arathranar in forum Fabrication
    Last Post: 10-20-2004, 01:49 AM
