Results 1 to 10 of 15
Thread: Carnetix P2140, No solder Power button, Wake on Link?
    Apr 2007
    Seattle
    I'm so close to being done, only thing left is to figure out how to bring my laptop, an Acer Aspire 3050, out of standby.
    I've set windows to go into standy when it no longer gets power from the P2140 or the wallwart, and I've gotten it to come back out of standby by putting a double-pole switch closing the wires of a lan cable, specifically, 1-3 and 2-6 SEPARATELY. Can't cross all four together, it does nothing. =\
    The switch works great, pops out of standby in under 5 secs, or short enough that I'm pleased with it. And I only need to flip it on for a second and the laptop wakes up (very pleased with that).
    My question is, can I use the white and green ACPI wires from the carnetix to trip low current relay (60ma) as the 'switch' and automate the wake sequence?
    Has anyone done this? Or am I barking up the wrong tree and should use the blue DELAYON somehow?
    I've searched for relays, carnetix, wake on link, etc and not really found an answer. And no, I really don't want to solder to my power button when this may work just as well.
    Any help is appreciated.
    Apr 2007
    Seattle
    Found more info...
    OK. I know it CAN be done from the number of Wake on Link/Lan threads I've found, but I'm hoping to find someone who has actually done it, and how.
    I'm figuring I could also use a Pulse Relay (momentary relay) off the power supply itself, but again I'm hoping to find someone who did it and the what's and how's behind it.
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    I believe that the 2140 already has a built in relay for the ACPI signal that is used for the Xenarc systems, it is activated by changing a jumper on the pcb.
    I an not 100 percent sure but I thing it connects to ground momentarilly. This should work perfectly for your case. You can find out exactly what it does ether by using a multimeter or if you are not very hands on just ask around in the carnetix site and forum. The guys there are very helpful.
    I hope that helps! You are lucky that your laptop does wake-up using this trick. many systems don't have that function.
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
    Feb 2005
    Boston,MA
    Just found this! Take a look!
    Apr 2007
    Seattle
    Hey, thanks for the link! I'd seen that one, what I keep hoping for is someone to post and say, 'oh yeah, I did that this way' or 'here's a schematic, bro!'
    I know, if wishes were fishes, we could ride seahorses...
    I'm gonna break out the ol' multimeter this weekend and knock something together.
    Apr 2007
    Seattle
    Cheating with the Wake on Link
    So, I decided to use a network switch I had laying around to manage my rebooting.
    Basically, by using a powered network switch, I'm able to have my Acer Aspire laptop resume from standby, hibernation, or even cold boot by going into the device properties for my network card and setting the proper box to allow the network card to bring it out of standby/hibernation.
    I have an old Dlink switch I had in the junk drawer, connected a regular network cable between it and the laptop, gave it some juice off the Carnetix 2140, and blammo, instant resume from standby.
    CURIOUSLY ENOUGH, I can also cold boot my laptop this way. Dunno why, but I'm happy it can.
    Final problem to solve: I can go into standby from RoadRunner and resume without ANY issues, but if I let windows or the Carnetix power supply do the standby my Audigy 2 ZS ntoebook audio goes to pot - all kinds of popping, crackling, and general noise. A reboot takes care of it and returns the audio to normal, so as long as I remember to use the software to do the standby I'm fine.
    Now to pack up all the gear and actually mount it in the car. Ungh. Out of the lab and into the field.
    Apr 2007
    Seattle
    The switch in question: Dlink 5Port Switch
    There's no on/off switch on it, so I've got 7.5v 1amp going to it from the carnetix to turn it on. Works real sweet, and no internal mods (soldering, jumpering) done to ANYTHING. YAY.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    well done m8, it seems you have sussed it out :-)..
    I dont understand what the difference is between asking rr to do it or getting the pc to auto hibernate/standby.. maybe guino can shed some light on it.. I dont think its a big problem and could be easy rectified by some simple code I guess.. let me know if you dont sort it and I will have a go at writing something that when it rec's the hibernation/standby command from the pc it then sends the command to rr to do the action.. this might fix your problem
    CdR
    Apr 2007
    Seattle
    Gonna take some more 'troubleshooting' to find that last little hiccup. I've been searching around for better Power Management software, but so far coming up short.
    Thanks for the offer, I've always simply shut-down my machines in the past so this Standby/Hibernate thing is still pretty new to me. Love the fact it snaps out of Standby in like 3 secs, tho. Gotta like a comp that responds like an appliance. =)
    Feb 2005
    Boston,MA
    Good call on the switch! Well done!
    Also having the pc cold boot from the net. card is definitely a bonus!
    Good luck on the field work
    Installing stuff in the car is always fun! Plan for some troubleshooting
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 05:53 AM
  2. Rewiring ATX power button
    By DCC in forum Power Supplies
    Last Post: 02-07-2008, 06:17 AM
  3. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  4. Options for Newbies for powering CarPC...
    By RoyN in forum Power Supplies
    Last Post: 04-23-2005, 05:00 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
