Results 1 to 2 of 2
Thread: Electrical static on monitor
    Oct 2006
    I have my vga cable running right along with the wires to power my inverter. When I turn on the computer there is a slight fuz or static on the screen. I checked the cable connection and it seems fine.
    Would it be that the power cables are close to the video cable?
    If so, aside from relocating is there a good type of insulator to use?
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    The general rule of thumb is to run power cables away from signal cables. They should at least be a couple of inches apart.
    Also check to make sure you are getting the right voltage to the screen. I know with my lilliput and my old xenarc that if they don't get at least 11v to 11.5v the screen would get noise or static across the screen.
  1. Mp3Car's Transflective vs. CarTFT TMR
    By ovsims in forum LCD/Display
    Last Post: 01-05-2008, 11:16 PM
  2. Help needed RGBS monitor - needs VGA input
    By Zductive in forum LCD/Display
    Last Post: 10-13-2007, 05:50 PM
  3. computer lcd monitor in car
    By BRADMAN in forum LCD/Display
    Last Post: 09-28-2006, 04:59 AM
  4. Small Monitor Suggestions?
    By rdunajewski in forum LCD/Display
    Last Post: 08-02-2005, 07:24 PM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
