Results 1 to 3 of 3
Thread: power questions
    Newbie jamiewhittingha's Avatar
    Jan 2005
    Savannah Tennessee
    power questions
    hi guys.
    I am just running around the web and trying to find out what the best power supply for the following specs would be.
    amb 1.2 ghz
    512mb ram
    20gb hdd
    I ran it to a cheap cig lighter invertor and it was not powerfull enough which i guessed would be the case.
    So I wanted to see if my battery would run the dam thing at all.
    I rigged some wiring which the ireing itself can handle to power but when I hooked it up to the battery nothing happened to the computer - nothing at all.
    For the temp setup to test if I would calling to much power I did the following.
    Wired an indoor extension cable from battery and had the computer on the floor next to my ride.
    then from the extension cord i spliced to a normal indoor three pin power cord - nothing happened.
    Any suggestions? I know the extension works as i did not mean to but touched the wires and they sparked. I even tried three diff PC's one was a crappy old P2 200mhz very low end unit.
    any suggestions to see if this will work - then the next question.
    Qhat kind psu do i do?
    1994 Jeep Grand Cherokee Laredo XP
    My CarPC Site
    Elsewhere
    1 - You're going to need to provide more details. "AMD 1.2Ghz" could mean quite a few different CPUs.
    2 - Read this thread: FAQ: Will <insert PSU model> Power Supply work with my system?
    It was written for pe9ople in your exact situation.
    How about the Wiki?
    Jan 2005
    Savannah Tennessee
    urm its a AMD 2000+ if that helps Its one of the cheapy ones that says 2ghz but really only works out being 1200.
    reading your pasting threat now.
    cheers
    My CarPC Site
  1. Power and video questions
    By dbrown504 in forum Newbie
    Last Post: 08-14-2006, 08:42 AM
  2. DC-DC Power Questions
    By Dan Patzelt in forum Power Supplies
    Last Post: 07-10-2005, 12:17 AM
  3. LiLLiput Power questions
    By eazyrog in forum Power Supplies
    Last Post: 08-04-2004, 05:56 PM
  4. Muppet power supply questions
    By phatbenny in forum Power Supplies
    Last Post: 07-20-2004, 05:25 AM
  5. power supply questions. + Schematic
    By Raas in forum Power Supplies
    Last Post: 10-31-2001, 12:02 PM
