Results 1 to 10 of 11
Thread: 12VDC to 12VAC
    May 2005
    12VDC to 12VAC
    I have a RS232 relay board that I want to install with my carputer so I can control 8 relays with the touchscreen for things like my garage remote, spot lights, etc. According to the manual, it says that it requires 12VAC to run. However, I have used it connected straight to the car battery and with 12VDC from a hacked ATX power supply.
    Should/could I run it straight from the ‘dirty’ 12VDC from the cars battery or should I be using a converter of some sorts to supply the 12VAC it requires? Would such a converter be expensive or could I make it using normal electronic components and a bit of breadboard?
    Low Bitrate MibMib's Avatar
    Jan 2006
    KyrGyzstan
    AC ???? - I think there is a mistake - DC must be.
    You can build simplest lm7812 voltage regulator ( follow ic's datasheet) and enjoy it - there must be DC I think!
    Good luck .
    400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
    Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    model #
    Quote Originally Posted by airborne_cookie View Post
    If you tell us more about the relay board we could probably figure out what it really needs. Manufacturer, model, etc.???
    ~Jimmy
    May 2005
    No, sadly it is AC.
    Here it is:
    http://www.velleman.de/ot/en/product/view/?id=351282
    I bought it a few years back.
    Nov 2005
    Austin, Texas
    DC is OK
    No, sadly it is AC.
    Here it is:
    Sadly is not true. Be happy. You can use 12V car power because the board will pass it through a bridge rectifier and then on to a 5V regulator. This is from the assembly manual which also lists the parts used.
    ~Jimmy
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    If you look at the schematic you'll see that it full wave rectifies and smoothes the 12vac to produce dc. You can feed it dc if you bypass that.
    Edit : too slow.
    Nov 2005
    Austin, Texas
    Quote Originally Posted by Rob Withey View Post
    No need to bypass. DC fed into a bridge rectifier will simply use two of the four diodes all of the time since the polarity never reverses. Just feed 12V in and the on-board regulator will work.
    ~Jimmy
    May 2005
    Awesome. Thanks guys. When I had a closer look and saw the diodes I thought that would be the case but wasn't certain.
    Would the fact that the 12VDC that comes from the battery isn't 'clean' (ie spikes and dips) cause a problem?
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by JimmyFitz View Post
    True, but you get 2 diodes worth of voltage drop and the ground will be different.
    Much cleaner to bypass it.
    Apr 2000
    Bedfordshire, UK
    12v doesn't always come from the battery. You'll get up to 14v out of the battery when the alternator is charging it.
  1. 12VDC to 12Vac
    By DjBac in forum Power Supplies
    Last Post: 09-29-2004, 07:38 PM
  2. 12vdc power regulator
    By greddy0 in forum Power Supplies
    Last Post: 12-23-2003, 08:29 PM
  3. 12VDC to 12VDC require an adapter
    By TrailMaster in forum Power Supplies
    Last Post: 08-30-2001, 09:38 AM
  4. 12VDC to 1.7VDC and 2.4VDC
    By citrus3000psi in forum Power Supplies
    Last Post: 08-17-2001, 10:08 PM
  5. +12VDC to -12VDC conversion
    By r0cket- in forum Power Supplies
    Last Post: 07-09-2001, 02:18 AM
