Results 1 to 8 of 8
Thread: Is M2-ATX capable of powering these devices?
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Here is my WorkLog (new):
    1995 Honda Civic Sedan EX - My First CarPC
    The main question now is regarding the Power Supply.
    I need power for the MoBo (12v), for the HDD (5v), USB Hub (5V) and Screen (12V).
    Do you know how many connectors comes with M2-ATX PSU?
    Do I need any optional parts for M2-ATX or maybe another Power Supply?
    Thanks!!!
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I'm sure the m2 would be adequate. If I remember correctly the M2 comes with 2 molex connectors (hdd, cd-rom) 1 mini molex (is that what they're called?) for a floppy, and of course the 20-pin motherboard power connector. Also has an optional P4 connector you can get.
    Tidder
    Try RevFE
    Nov 2006
    Sao Paulo, Brazil
    Hi!
    But what about the Screen? What connector is used to power the Lilliput?
    Thanks!
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
    Elsewhere
    Make your own. Wire the pose connector for the Lilliput screen to a male molex HDD connector.
    Yellow wire is +12v and the black wires are ground. The red wire is +5v and won't do anything.
    How about the Wiki?
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by DarquePervert View Post
    Hi. So I will get the HDD connector and split it in 2, one will power the 2.5' HDD and the other will go to the Lilliput.
    On the Lilliput side, I will change the connector to become a male HDD connector.
    Is that it?
    Thanks!
    \/ |_ /\ [)
    1995 Civic Sedan EX
    _
    Mar 2004
    Little Elm, Texas
    don't the smaller laptop drives require a specific power adapter?
    not to mention an adapter to go from the 2.5" form factor to the 3.5" form factor for the IDE plug?
    Jan Bennett
    Elsewhere
    Quote Originally Posted by RedGTiVR6 View Post
    That adapter usually has a molex HDD connector for power.
    How about the Wiki?
    Nov 2006
    Sao Paulo, Brazil
    Yes you are right. I've bought this adapter:
    http://www.ciadosoftware.com.br/prod...&dep=7&cat=106
    For around U$15,00 and it converts data and power for the small HDD.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  1. Micro ATX or ATX
    By custardbomb in forum Power Supplies
    Last Post: 08-14-2005, 07:48 AM
  2. powering a VIA MII w/ a ATX powersupply
    By boostedGT-S in forum Power Supplies
    Last Post: 01-20-2005, 01:57 PM
  3. A solution for powering 12v stuff inside
    By zootjeff in forum Power Supplies
    Last Post: 12-17-2004, 07:21 PM
  4. Powering a datalux screen from atx psu
    By Speedpass101 in forum Power Supplies
    Last Post: 10-08-2004, 04:19 AM
  5. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
