Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Opus 150W and dead battery...?
  1. #11
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    hey dude when I meet up with you we can try switching your battery with the one from my car, its dead right now but we can charge it before we put it in, and if it works we can work something out where you can keep both batteries... let me know.
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Engine died)
    Work Log v4.5 --> 05 Toyota Tundra DC SR5
  2. #12
    Dec 2006
    MA, USA
    That is if it fits...
  3. #13
    Mar 2007
    it could be a ground cable somewhere, or the voltage regulator, get your alternator checked, the car should NOT shut off if the battery dies. you should be able to unhook the cables and pull the battery out while the car is running, and it will keep running, if not, its the alternator.
  4. #14
    Dec 2006
    MA, USA
    Quote Originally Posted by RMerritts View Post
    not necessarily, what he described wasn't his car shutting off but things in his car acting up as the power fades in and out. That is exactly what happened in my car when the cable between my alternator and battery went bad... lights dimming/not turning on, radios and computers acting up, and the car not starting after its been shutdown. Also since the battery did not have any real time to charge up in between the separate runnings of the car it became less and less charged resulting in more of the before mentioned problems even though there was no large power drain anymore. Its a pain in the *** and not always that easy to diagnose but none the less thats almost exactly what happened to me.
  5. #15
    Mar 2007
    maybe his alternator cant handle the wattage, you CAN run a car without a battery for miles and miles and miles etc. until u shut it off, its there to power the starter and accessories pretty much, but that system is still putting a large load on the alternator.
  1. FS: Misc parts. Opus 150w, Lilli TS 4 chan AMP
    By tiggs in forum Classified Archive
    Last Post: 07-04-2005, 12:03 AM
  2. 150W OPUS died after only a few hours of use???
    By bndrpa in forum Power Supplies
    Last Post: 06-28-2005, 04:44 PM
  3. Dead Battery
    By Matthew230 in forum Power Supplies
    Last Post: 03-24-2005, 02:38 PM
  4. 150w opus, both leds blink once, then 20second pause
    By diablo266 in forum Power Supplies
    Last Post: 03-21-2005, 06:58 PM
  5. Help Opus Draining Battery
    By xcntrk75 in forum Power Supplies
    Last Post: 02-28-2005, 04:22 PM
