Results 1 to 2 of 2
Thread: Carnetix P2140 Firmware 1.8.3 BETA
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    I just wanted to let people know on this update because it covered one of my biggest needs. Secondary power control! (read on to understand what I mean)
    Here is the link to the carnetix forum.
    This is a BETA so please do not blame me or the carnetix guys if things don't work for you! Other than that everything works as advertised on my setup.
    Among other additions and updates they did the following:
    Revised the Secondary Off control to either follow Ignition or (SDLO) instead of PriOut. This will allow users to turn off their USB devices AFTER the computer (typically Mac mini) has entered Sleep mode so that they will be recognized when the computer wakes from sleep .
    I had this function simulated by en external timer up to now but this made thing way simpler. I use standby and this works very well because if the USBs like my touchsceen, WiFi stick, cameras, bluetooth and many more turn off before the PC goes on standby things don't work well in resume.
    I also have any unnecessary power consumers controlled by this so the system can be in standby but XMradio, LCD, KR1 router, some USBs(since my via powers the USBs in StandBy) cab be completely off (relay controlled).
    Also the low temperature threshold was something is was going to implement and here it is! (Yes Boston gets pretty cold!!)
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    great firmware update. Just updated my 2140(Been putting it off since it meant yanking it out.)
    I might use a pigtail extention on the bootloader jumper. That way I can trigger it while its still in the car.
    This also solves my "Device cannot start" issues I had with 1.4.x(1.4.4 still had the problem)
    Since we have similar setups i'd be interested in seeing your layout/setup.
    Also, mikeH has released a api sdk for psumoni! That means we can get roadrunner and other frontends to pull the info directly. Looking foward to that!
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  1. Carnetix P2140, No solder Power button, Wake on Link?
    By Coyote65 in forum Power Supplies
    Last Post: 06-17-2007, 01:09 PM
  2. Auto Start Up and Shutdown with Carnetix P2140
    By stupidjunior in forum Power Supplies
    Last Post: 05-17-2007, 05:01 PM
  3. Problem with Carnetix P2140
    By Nola111 in forum Power Supplies
    Last Post: 05-16-2007, 05:43 PM
  4. Replies: 0
    Last Post: 03-30-2007, 04:44 PM
  5. Carnetix P2140 PSU - Mac Mini
    By danielbriggs in forum Power Supplies
    Last Post: 01-08-2007, 10:45 AM
