Results 1 to 3 of 3
Thread: Do i need an "intelligent" psu?
    Newbie RichIbizaSport's Avatar
    May 2007
    Hull, UK
    Not quite sure how to name the title
    Basically, im in the process of building my carputer, and was looking to buy a m2-atx.
    As ive kept my headunit in my fabrication (radio/cd for short journeys) i dont want the pc to start auto. I want to place a power button to start it manually. But i do want an auto shutdown feature with turning off the ignition
    The question is: Do i need an "intelligent psu" like the m2-atx / opus etc. Is there a cheaper alternative as i only want the shutdown controller?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    shutdown is part of the intelligent bit so yes you do have to if you want a shutdown controller. You could also use your button to shut it down of course but that isn't auto. What car power supply you could use that doesn't have a controller I have no idea.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Variable Bitrate billmee's Avatar
    May 2005
    You have a lot of options
    Easiest is a Startup/Shutdown controller with a switch on the ign/acc signal.
    You could control the psu with an instantaneous switch that is latched by the Ign/Acc signal. To do this you need some knowledge of /access to simple relay circuits.
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 07:45 AM
  2. 650W PSU blew up my dual XEON setup
    By Chris31 in forum Off Topic
    Last Post: 09-23-2006, 07:55 AM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
