Results 1 to 3 of 3
Thread: Inverter safety question.
    Apr 2007
    Hi, I have installed my CarPC and have everything done, the only thing left is I have my inverter in the trunk of my car and would like to rewire my power switch to my dash. So I opened up the inverter and saw that both wires of the swithc were red, and my friend told me to just extend the wire and have the same switch in my dash.
    I just wanted to know if this was safe and would you guys do anything else??
    Thanks in advance.
    Variable Bitrate billmee's Avatar
    May 2005
    Sounds like an acceptable way to control the inverter.
    BUT this should only be done if the switch carries a control signal.
    You can determine this by the gauge of the wires, if they are a lot thinner than the connections to the cars electrical system you should be okey dokey.
    Don't do it if the wires carry the total input or output of the inverter. In this case the red wires will be as thick as the battery or cigarette connection wires.
    Apr 2006
    Saint Petersburg, FL & Flint, MI & Auburn, NY
    I have an inverter built into my console right now powering my external hard drive and laptop.
    If your inverter has a main switch on the housing that is to control the power on-off then I would recommend having that switch permanently on. While the power that you are running to it have a switch on it. Simple and practical. Just put a switch between the main power source (battery or ignition) and the inverter. This saves you having to take the inverter apart.
    1996 Accord Ex Carputer
    Soon to come 2008 WRX 5-door Mac-carputer.
  1. N00b inverter question
    By sebberry in forum Power Supplies
    Last Post: 03-09-2006, 08:56 AM
  2. PSU/MB converter and Inverter question
    By Windsetter in forum Power Supplies
    Last Post: 02-23-2006, 07:04 AM
  3. Inverter relay question
    By Pudge in forum Power Supplies
    Last Post: 06-02-2005, 01:42 AM
  4. Replies: 13
    Last Post: 09-20-2004, 07:01 PM
  5. A newbie inverter question
    By Cliff in forum Power Supplies
    Last Post: 03-29-2002, 10:10 PM
