Results 1 to 10 of 12
Thread: CNX p1900 question
    Jun 2007
    Flagstaff AZ
    CNX p1900 question
    So I've spent too much time on this forum, searching and rarely posting. There is one power supply question that has been haunting me. (literally my roomate said I was yelling about switched 12v somthing last nite)
    My cig lighter is on an acc circuit, can I just tap into it for the 12v acc line?
    Would that effect the functionality of my cig lighter?
    I beleive the answers are yes, no. but I would love to hear of someone else who did this with success. From my understanding, or at least reading, the power supply does not draw much at all from the 12v switched line it just uses it for an on/off signal.
    All of my stuff comes in tomarrow, I plan to put a full write up soon wth pics after it's done. Thanks a ton guys
    my project:
    mac mini (non-inte)-going in the glove box (it's too easy not to)
    cnx p1900 v2.2- going under driver seat (depending on clearance)
    lil 629- in the dash with bracket, I've seen pics and it looks oem.
    subaru mounting bracket for screen
    also i'm contemplating quitting my job so i can do it tomarrow, is this a good idea?
    Apr 2007
    Yes, quit your job, it's a great idea. Stop being a slave to the man.
    You're better off not tapping into anything to wire up your power supply, they draw too many amperes. You need to wire up your power supply as you would a car audio amplifier.
    Jun 2007
    Flagstaff AZ
    even the switched 12v? I've heard of many people hooking it up to the one that runs to their head unit and its a stock headunit with a built in amp...I would still run a main from the bat to the supply.
    Elsewhere
    Quote Originally Posted by mgetchis View Post
    Yes, that's perfectly fine, and it won't affect the functionality of your cigarete lighter at all.
    The ACC line on teh intelligent PSUs is just used for sense. When it senses 12v, it signals the computer to turn on. When it senses 0v (or lower than the threshhold), it signals the computer to turn off.
    I haven't atually done it. I used an ignition controlled line in my car stereo harness.
    It works.
    Only you can answer that, but i'd say that quitting your job is a rather stupid idea.
    How about the Wiki?
    Jun 2007
    Flagstaff AZ
    Thanks, I'm going to start installing today. (when I get off of work)
    Jun 2007
    Flagstaff AZ
    Can I also use the cig lighter for the switched 12v for my amp as well as the p1900?
    Feb 2007
    Maryland
    Bump!
    I have a similar question/problem on my hands about the p1900 and the ignition line.
    I have half of my carPC installed, so far its just the mini, so no screen. The p1900 is hooked up to the battery and grounded properly and is hooked up to my cig lighter which is only on when the car is on, so it counts as ignition.
    The problem I have is when I turn on the car, neither the p1900 or the mini start up, no fans no nothing. When I apply power it does give me the firmware version. The weird thing is that it tells me the firmware is 2.9 (2 flashes, 1 flash, then 9 flashes), and I thought the firmware was only up to 2.8.
    I tested the ignition line and the continuity is fine, and the 12v line receives 12.5 volts when the key is on acc and 14v when the car is on.
    Please don't flame me, I did search! I swear it!
    CarPC status:
    [XXXXXXXXXX] 100% Complete
    [XXXXXXXXXX] 100% Installed
    [XXXXXXXXXX] 100% Software
    CarPC v1.2 is now in effect. Software updates and hardware additions to come.
    Jun 2007
    Flagstaff AZ
    I had similar problems with hooking up to my cig lighter...never really did figure out what problem was. Instead I just used the acc line out of my head unit. well actually I dont have a head unit anymore. I bought a wiring harness at a car audio shop, one with pigtails on one end an female on the other. this plugged into what would go into a head unit, it labels the wires for you. very easy
    Mar 2007
    Quote Originally Posted by KryptonianJorel View Post
    Dumb question, but have you tried hitting the power button on the mini, and/or if you have a macpac cable have you connected the little power button thing onto the main board?
    Feb 2007
    Maryland
    Yes, i hit the power button and yes, i hooked up the macpac correctly. I'll have to try to wire it to my radio ign line, and if that doesnt work, I would have to say the p1900 is dead.
    CarPC status:
  1. Questions about my setup and the Carnetix P1900...
    By Nola111 in forum Power Supplies
    Last Post: 05-14-2007, 07:35 PM
  2. P1900 shutsdown randomly or sometimes does not turn on.
    By ephyouckay in forum Power Supplies
    Last Post: 03-28-2007, 08:54 PM
  3. P1900 + Dell Laptop and docking station
    By wittless in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-07-2006, 12:20 AM
  4. Sleeping Mini/P1900 Question
    By Bugbyte in forum MacCar
    Last Post: 08-18-2005, 05:45 PM
  5. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 07:22 PM
