im pretty sure my computers grounds are all the same....(connected)...so that wouldnt work.
1.9in x 2.9in -- 47mm x 73mm
Like the other guys said resistors are the wrong way to do this. A resistor is a current limiting device not a voltage limiting device. It only drops voltage once you have reached the circuits current limit. You cant guarantee the same load all the time so you wont get the same voltage.
Options are buy a proper regulator or buy a new hub.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
It's possible that the first component off the 7.5v is a 5v regulator. If you could identify it, you could rip it out and tap in there. But that may not be the case.
stupid question, but have you tried running it off 5v? I've had some 6.5v hubs run fine off 5v...
Yea you cant use resistors in this case to drop the voltage. Your hub may be rated at X watts, but it does not always draw that much power. You only use resistors to drop voltage from a device that has a constant resistance, like a light bulb or another resistor. You might want to consider building a voltage regulator. Search up schematics for a lm317, as you can easily build a regulator with that chip.
