Results 1 to 10 of 19
Thread: need help with Resistors.
    Mar 2007
    Lancaster Pennsylvania
    Unhappy need help with Resistors.
    alright, i dont know if this is the right place to put this...but its dealing with power....so here goes.
    i have an external usb hub that i 'hacked' into the front of my emachines case.
    right now i have it powered by 'self' instead of 'bus', however, i only have 5v tapped from PS going to the dc input on the hub...its rated for 7.5v.
    would anyone be so kind to explain what resistor(s) i need to take 7.5v from the 12v coming from the PS?
    thanks.
    -Keaton.
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    If you want a simple resistor-divider circuit, you need more info... how much current does the hub draw? Is it constant current or does it vary with load? How much does it vary? How large of a input voltage window can the hub take?
    Since this probably isn't a constant current draw, you might want to look into voltage regulation instead of resistor-divider.
    Mar 2007
    okay, then whats the easiest way to get 7.5v dc @2100ma to the hub?(from the interanl PS?)
    im not picky...i just need it to be able to power/run my ipod/high power usb devices...
    hers a link to the hubs descripition
    Code:
    http://www.techexcess.net/belkin-4-port-usb-hub-f5u021.aspx
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by keatonreckard View Post
    Code:
    v=ir
    r=v/i
    You need to drop 4.5v at 2.1A, so R=4.5/2.1 = 2.14ohms.
    However, if the hub draws less current (very likely), the voltage drop will be less and you'll be feeding more than 7.5v into the hub and the magic smoke might escape.
    Safest way is a 7.5v regulator, a resistor is not the right solution here.
    Mar 2007
    well, im 16 and have no job... so im not gonna go buy anything huge.....i have a ton of old resistors in the barn...so...i just need it to work...not be perfect...so would it be better if i took it down to like 6.5v? so then it would blow up if i unplugged my ipod?
    Apr 2000
    Bedfordshire, UK
    do it right, do it once.
    do it wrong, buy a new hub.
    my advice, don't bodge it, do it right.
    Mar 2006
    Colorado, but Canadian!
    Just buy a new hub that takes 5v. They are what, $10, $15 new? Maybe less used somewhere. That's 2 hours work at minimum wage. Im sure you could mow 1 lawn and get yourself a new hub. Or before you start hacking things up, sell yours on ebay, and buy a different one that takes 5v.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    well...this hub is already crammed into the front area of my case...(like the plastic part where the status leds are and such...seperate from the inside of the case..) and im trying to spend as little money as possible....ive gotten everything in this compy for free....except a few leds...
    the hub is constantly connected to
    (1) a usb to ide adapter for my dvd burner...
    (2) a usb bluetooth dongle...
    (3) and ipod usb cable that comes out to the front of the case..
    (4) a hacked usb extension cable to keep the use of the front mounted usb port...
    the 5v i have connected powers everything fine except high power devices...
    such as usb to sd/mmc/MS/xd adapter, ipod, keyboard...etc...
    so would the voltage really differ that much with the ipod(connected or unconnected) being the only changing variable?
    Apr 2000
    Bedfordshire, UK
    You already defined the ipod as a high power device. Therefore it will have a significant effect on the current, and therefore the voltage drop.
    So the answer to your question is "yes".
    Jun 2005
    Oakland, CA
    Yes, the power will fluctuate too much. Actually, just had a thought. Take the 12v and 5v from your PSU and you'll have your 7v. I don't recommend it, but it's been done. Don't blame me if you screw up your PSU, though!
  1. Resistors caps diodes OH my!
    By rotarypower101 in forum Hardware Development
    Last Post: 04-30-2006, 11:39 PM
  2. FS: 75 Ohm Resistors (4 Available)
    By AEFL92 in forum Classified Archive
    Last Post: 02-08-2005, 09:12 PM
  3. Resistors
    By belmontboy in forum General MP3Car Discussion
    Last Post: 03-26-2004, 12:21 AM
  4. Using resistors
    By babas151 in forum General Hardware Discussion
    Last Post: 03-27-2002, 02:57 PM
  5. advice needed on variable resistors for LCD
    By asteroid in forum LCD/Display
    Last Post: 10-16-2001, 01:46 AM
