Results 1 to 3 of 3
Thread: M2-ATX timing options.
    Nov 2006
    Is it possible to reprogram the m2-atx with different timing options?
    I have done various pic programming before.
    I want to be able to change the amp turn on delay. The amp turns on before the pc has fully booted and when the sound card is initialised, it pops.
    I am upgrading the soundcard, but another solution is to delay amp turn on until my frontend and sound are fully started.
    Also I just want full control over it for whatever I may need to do.
    Has anyone done this? Can the source code be had?
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Check this thread. I believe the M1 and M2 share the same source code. You could double check with user Andrewb to be sure. Another option is to download your firmware from your M2 and compare against the published source.
    M1-ATX microcontroller source
    Nov 2006
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 08:04 PM
  2. M2-ATX Problem - Fan runs but does not boot !
    By Autonator in forum Power Supplies
    Last Post: 11-14-2006, 05:22 AM
  3. Wtb: M2 Atx
    By EsKALad in forum Classified Archive
    Last Post: 01-03-2006, 08:59 AM
  4. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 08:06 PM
  5. What are the ATX DC to DC power supply options?
    By Squeezer in forum Power Supplies
    Last Post: 07-08-2002, 04:25 PM
