Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: M1 issues, please help (somewhat technical)
  1. #11
    Aug 2006
    Atlanta, Ga
    sounds like the m1's buck or boost regulator is not operating like it should make sure no resistors or caps are damaged. What is the input on the m1 12V?
    Car PC Status {------- }0%
    Car Died along with Autonode Monitor after returned to me. Worked for 3 Months then died again. The car engined died not long after!
    Upgraded to 2003 Infiniti G35 Coupe
    Exploring options of a double din unit style Car PC.
  2. #12
    May 2007
    I can set the input to whatever I want, it was at 13.5 when I measured the rail voltage
  3. #13
    May 2007
    So im looking to buy a new M1 on ebay and I saw the following note:
    Please do not try this PSU with Pentium 4s. It works with all VIA mini-ITX boards, some low power Pentiums and AMDs. Please check your motherboards specifications and make sure that the CPU is not getting V(core) from the 12V rail (should be on the 5V rail). Avoid motherboards that have 4 pin 12V ATX connectors, which is an indication that the motherboard is using 12V for V(core).
    Just wondering if that could be the issue?
  4. #14
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    No, not really. That warning is just for boards with huge power draws. Yours is so minimal, it's most likely fine on that aspect. Sorry, I have no other advice for you.
  1. Touchscreen Issues w/Hibernation & CNX-P1290
    By jmciver in forum Power Supplies
    Last Post: 12-20-2006, 08:48 PM
  2. Turn off Delay ... ideas please ....
    By JPMG in forum Power Supplies
    Last Post: 10-24-2006, 01:02 AM
  3. What does m1 led indicate?
    By a-ten in forum General Hardware Discussion
    Last Post: 09-18-2006, 07:23 PM
  4. M1 , M2 , Opsus & EP13000 Informative Thread
    By Philhop in forum Power Supplies
    Last Post: 07-04-2006, 03:17 AM
  5. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 02:16 PM
