Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: M2-ATX +5V and +3,3V dead?
  1. #11
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by Lasse Poulsen View Post
    Hello..
    I have a M2-ATX plugged into my micro-atx motherboard with 2600+ amd sempron cpu, 512mb ram, 120gb ide harddrive and the M2-atx is powering my touchscreen too..
    This is my third M2-ATX, I had two before that burned a component (Others have had that problem in here)
    Methinks you might be overdrawing your powersupply.
  2. #12
    Jul 2006
    On the +5V and +3,3V line? I don't think so The only load on that line is the motherboard and harddrive.. that's not much..
  3. #13
    May 2005
    San Clemente, CA
    Quote Originally Posted by parksgm View Post
    Methinks the M2-ATX is grossly overrated and has no OVP.
    The M1 and M2 are probably fine for running VIAs, but I had many die inexplicably with modests amounts of wattage thrown at them, well under their rated limits and even with active cooling.
    Lasse, do yourself a favor and pony up for an Opus 150w.
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
  4. #14
    Jun 2007
    White Salmon, WA
    I am trying to test an m2 also. But I have really stupid question. If you throw 12V at it, does it just automatically turn on?
  5. #15
    May 2005
    San Clemente, CA
    It's supposed to.
  6. #16
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    Ok katz, if you read the 1st post, The culprit here is the HD. When he unplug it, it works fine. It seems that the Integrated Drive Electronics are shorting out (Most likely the spin motor.) I've had HDs lock up my PC, I mean, hard lockups that I have to clear the CMOS to get the board to turn on again. I'm on my 5th HD in 3 years in this hobby. (I think the 2 15'' Subs have something to do with it.) But anyways. The Hard Drive is the one acting up.
