Results 1 to 10 of 16
Thread: M2-ATX +5V and +3,3V dead?
    Jul 2006
    Hello..
    I have a M2-ATX plugged into my micro-atx motherboard with 2600+ amd sempron cpu, 512mb ram, 120gb ide harddrive and the M2-atx is powering my touchscreen too.. Nothing else.
    I plugged it into the car and powered on.. Worked fine, when I was driving the next day, the computer shut down after ~10min, and wouldn't power up again.. The harddisk made funny noises, like powering up and loosing power, I then tried to remove the power from the harddisk, and the computer powered up fine.
    So I took the computer inside and put +12V on the m2-atx from a standard computer psu (~400W), and the computer powered just fine. I then put the carpc back into the car, and nothing happened when I powered it up. I then tried to measure the volts;
    Between yellow and black=+12,32V
    Between Red and yellow=+12,32V (Should be +7V??)
    Between Red and black=0v
    I have then later tried to measure the +3,3V, but that's dead too.
    I measured the total power usage of the m2-atx to 7amps, on the input.
    It went to around 15Amps shortly on startup.
    There is no components that look burned, or smell burned.
    My question then is, is this a simple problem? Or can I consider the M2-atx as dead?
    This is my third M2-ATX, I had two before that burned a component (Others have had that problem in here)
    Aug 2006
    Atlanta, Ga
    Sounds like a user error :-(
    Im not sure what you think u are doing but u obviously have some issues in your wiring setup look at the attached image for a guide on the voltage rails. Where are you getting your M2 PSUs from?
    Car PC Status {------- }0%
    Car Died along with Autonode Monitor after returned to me. Worked for 3 Months then died again. The car engined died not long after!
    Upgraded to 2003 Infiniti G35 Coupe
    Exploring options of a double din unit style Car PC.
    Jul 2006
    I am working in my daily life as an electrician, so I have a little clue about what I am doing, but there isn't any +5Vdc in the molex connector. neither +3,3V or +5vdc in the atx 20 pin conector..
    Aug 2006
    Atlanta, Ga
    Quote Originally Posted by Lasse Poulsen View Post
    Hello..
    Between Red and yellow=+12,32V (Should be +7V??) Dude red wire is 5 volts! yellow is 12 Volts
    What are u using to measure? And How are u getting a Current(I Amp) readings are you using a bench supply or a DMM to get the data.
    Aug 2006
    Atlanta, Ga
    which molex connector?
    Do you have the pin 14 grounded to turn on the PSU ON pin? This turns on the voltage rails.
    Jul 2006
    I am using a Multimeter to measure the voltages and current amps.
    In the 4 pin molex connector I can only measure the voltages above.
    And yes, the pin 14 is grounded, since there is +12V in the 4 pin molex connector.
    Aug 2006
    Atlanta, Ga
    You should not use the multimeter to measure the amps it can add a load to the supply thus making your m2 atx crowbar becuase you probably have the Multimeter set to what current limit 10 amps? The m2atx is probably current limiting on that rail that you are checking. is the inductors (big square parts) getting warm?
    Jul 2006
    The multimeter is not making a great load.. Probably something like 0,1-0,5amps at max.. And the multimeter was at the input of the m2-atx..
    And the 2 inductors where warm.. and the others wasn't.. And now there isn't any +5v
    Elsewhere
    Maybe it's me, but llowing current to pass from +12v to +5v would be bad, woudl it not?
    How about the Wiki?
    Jul 2006
    what?
    I have measured the current from the INPUT side of the m2-atx.. no current limiting, no extra load on m2-atx..
    On the OUTPUT side I have only measured the voltages, which isn't there, on other than +12V
