Results 1 to 2 of 2
Thread: Help with OPUS 120W wiring
    Apr 2007
    Before I do my install tomorrow I want to make sure I have all my T's crossed and I's dotted.
    I will be running a 10AWG wire from my car battery directly to the OPUS unit, while using a fuse of course. The OPUS has 16AWG wire coming from it, now here I will use a butt/twist connector to connect both the 16AWG and 10AWG wires together and not solder it, I'm not very good with soldering.
    Next I will run an 18AWG wire from the ignition switch, the same wire that I would call the "remote" wire if I were running an amp. directly to the OPUS.
    This is the only part of the entire install that concerns me because I dont want to connect a 10AWG wire directly to a 16AWG wire without knowing something important.
    Also, should I go 8AWG?
    If everything looks good let me know and wish my luck Saturday morning.
    Apr 2005
    Queens, New York
    10 gauge should be sufficient....I ran 8 gauge. But just make sure you have the correct size fuse...dont over power/underpower.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  1. opus 120w jumper help
    By nxhorr in forum Power Supplies
    Last Post: 08-21-2005, 08:11 PM
  2. Can someone double check my Opus wiring please
    By Bailey in forum General MP3Car Discussion
    Last Post: 01-19-2005, 03:57 AM
  3. Stupid question about OPUS wiring
    By RS3RS in forum Power Supplies
    Last Post: 08-31-2004, 01:33 PM
  4. OPUS Wiring
    By ikhonlord in forum Power Supplies
    Last Post: 08-24-2004, 07:00 PM
  5. opus 90w wiring and computer wont shut
    By scw5179d in forum Power Supplies
    Last Post: 04-30-2004, 05:20 PM
