Results 1 to 2 of 2
Thread: Simple question...
    Aug 2006
    Simple question...
    So, I have searched and found that I need to have a large gauge wire run through the firewall in my car to my Opus 250w to the battery and that tapping into the wiring harness' lines could cause a potential fire.
    However, I have not read much about the acc line. Do I need to run a large wire from somewhere (if so, where?) to the acc line on my PS, or can I tap into the harness' acc line?
    Thanks for the help and potentially helping me prevent my car going up in flames
    CT
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by ctsoccer13 View Post
    CT
    Its good to see you did some research!
    The acc line is just a remote line. You can use any wire, and tap into any source you want. It draws milliamps, so your wiring harness is fine for the remote line.
    1.9in x 2.9in -- 47mm x 73mm
  1. Fairly simple carputer/amp question
    By RyanB95 in forum Car Audio
    Last Post: 02-02-2007, 09:56 PM
  2. simple wiring question
    By yonu in forum Power Supplies
    Last Post: 01-19-2007, 05:00 PM
  3. simple lilliput ribbons question
    By avidan in forum LCD/Display
    Last Post: 01-27-2005, 09:28 PM
  4. Simple Wiring Question
    By ukchris in forum LCD/Display
    Last Post: 12-30-2004, 01:43 AM
  5. simple question - cd changer control
    By tbone in forum General Hardware Discussion
    Last Post: 09-09-2001, 08:51 PM
