Results 1 to 10 of 10
Thread: M2-ATX not working
    Dec 2006
    Edmonton, AB, Canada
    M2-ATX not working
    Hi, I had finally got all my parts a couple weeks ago and hooked everything up. The only problem now is my PSU (M2-ATX) is not working at all. I am using a Via Sp-13000 board. When I hook up power (I have tried both in my truck and on an external 12V power supply (rated for 400 watts) nothing turns on. I have checked the fuse and its fine. When I test the outputs of the atx 20 pin connector I get the following the results on the multimeter:
    Pin 2 - 5.54 Votls
    Pin 14 - 5.52 Volts
    Everything else registers 0 Volts.
    unfortuntatly I bought this PSU 6 months ago (ebay - short-circuit) so I doubt there is a possiblity of a return/replacement.
    Any idea's or am I SOL?
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    Put a jumper across the PS_ON# to a COM and it will activate the power supply. Then you should be able to test all the outputs.
    Also, be sure you have the power, remote, and gnd connected to the power supply. All three connections are necessary.
    Dec 2006
    Thanks, that worked great. All voltages when jumpered are fine. But now I don't know why its not turning on. I have the on switch connected to the right jumpers on the motherboard, but still nothing. Any more suggestions?
    Aug 2006
    Atlanta, Ga
    Make sure you have the jumpers on the M2Atx setup correctly the section below the PIC micro.
    Car PC Status {------- }0%
    Car Died along with Autonode Monitor after returned to me. Worked for 3 Months then died again. The car engined died not long after!
    Upgraded to 2003 Infiniti G35 Coupe
    Exploring options of a double din unit style Car PC.
    Mar 2007
    Quote Originally Posted by Arrow View Post
    when you say remote, you mean the ignition wire, right? for signal?
    Aug 2006
    Atlanta, Ga
    You need both Ign tied to a switched 12V source and the remote on header next to the ATX header picture about its the 2 pin header in the middle this is cabled to the two pins on your mother board system header that should say PWR_SW or PWR_BUT, or something to the effect of power on and when you have the ignition signal high (12V) then the M2 will attempt to power on your motherboard like a button press on a desktop.
    Feb 2006
    West Lafayette, IN
    Quote Originally Posted by Snortonnorton View Post
    Yes, Ignition. I forgot that there was a remote out on the power supply... Don't use that as an imput.
    Mar 2007
    what exactly is the remote out?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    I believe it is to trigger the another device, like an amp.
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    I use my remote to power the amp and the fan I glued on top of the M2-ATX
  1. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 04:36 PM
  2. Stupid M2 ATX !!
    By rxh81 in forum Power Supplies
    Last Post: 03-21-2007, 12:56 PM
  3. M2 ATX with remote starter question?
    By david69leonard in forum Power Supplies
    Last Post: 02-05-2007, 05:50 AM
  4. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 07:51 PM
  5. Presario AT or ATX?
    By ppgt94 in forum Power Supplies
    Last Post: 04-11-2002, 04:45 AM
