Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Weird power problem
  1. #11
    Jun 2006
    My setup is doing exaclty the same as described above. I am using a 500W invertor, connected through a relay pretty much directly to the battery. I am starting to think that Invertors are less than ideal as they all use modified sine wave output and it just seems to interfere with laptop PSU and i guess PC ones.
  2. #12
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    A new inverter is like $40. It's a quick and relatively cheap troubleshooting attempt. If it works, great. Worth $40.
    If it doesn't, well you've got an extra inverter. You'll need it eventually anyway.
    But I'd also try the time honored procedure of taking the whole system apart, putting it back together, and seeing what happens. I can't count how many times I've tried to diagnose a problem and missed it, only to fix it unknowingly by taking it apart and putting it back together.
    You could have some kind of unnoticeable short in the electrical connections somewhere for all you know. Taking it apart and putting it back together could remove whatever was shorting the system out. Just as an example...
  3. #13
    Jun 2006
    Sadly I am using a new invertor, my old one was only like 150W but had the same symptoms. Im guessing il have to spend the 100$ to get a dc-dc and run the laptop from that?
  1. Power problem
    By Skipjacks in forum General Hardware Discussion
    Last Post: 12-10-2005, 07:50 AM
  2. power inverter power supply shutdown problem
    By launter in forum Power Supplies
    Last Post: 09-21-2005, 12:12 PM
  3. need help with power problem...
    By BlueVisor in forum Power Supplies
    Last Post: 07-31-2005, 11:14 AM
  4. Power supply problem...
    By simone in forum Power Supplies
    Last Post: 05-18-2005, 03:14 PM
  5. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
