Results 1 to 9 of 9
Thread: PC rebooting when car is started.
    Constant Bitrate Outsider787's Avatar
    May 2006
    I just installed my first setup in my car. Epia EN15000 and a Xenarc screen.
    I have extended the power button all the way to the front, so I can power the PC on and off from the drives seat.
    Anyway, if the PC is already on when I start my car, it will cut out, and reboot.
    I guess all the current from the battery is going to the starter, and there isn't enough to power the PC.
    Is this normal behaviour? Just want to make sure I've not dome something stupid, or that I've wired things incorrectly.
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    you need to have an "intelligent PSU" that is able to withstand the engine cranks...like an OPUS or the M2ATX PSU...these are build specifically for car PC's
    edit: let me rephrase that...it doesnt need to be an intelligent PSU...but it does need to be able to survive cranks which are as low as 7 volts...an intelligent PSU is one with an automatic shut-down controller
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
    May 2006
    so these intelligent PSUs, will take the 7v (or whatever is left durring cranking) and still be able to make the 12v, 5v, and 3.3v ?
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    Yes
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Usually I do not comment on these questions, but it would help you greatly to search before starting a thread. I do believe there is a forum specifically for newbies (yourself) that will help you a lot.
    New Age Garmin - Skin for RR
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Additionally the vehicle charging system has an impact. They are not all created equal.
    Follow ThunderStick's advice.
    TruckinMP3
    Read the FAQ!
    Low Bitrate slantman's Avatar
    Apr 2005
    north augusta SC
    i fixed my by installing a 1 farad cap in line with the battery input.
    Voy
    Voy is offline
    Jun 2007
    Thumbs up
    Without intelligent PSU probably it`s better include before cap a diode ~ 20 Amps.
    It lowers 13 v to 12 v but holds it up, when engine side falls to 7 V.
    Best of course replace cap with small 12V battery.
    Jun 2006
    Chicago, IL
    carnetix DC/DC PS will do the job, I have one and it works great.
    EPIA TC 1G 256MB 60GB Linux,WindowMaker, Roadnav, Xine, XMMS, iGuidance3
    Lilliput 8", Pharos i360, WUSB11v2.6 WiFi
  1. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 08:44 PM
  2. car PC in 66" mustang
    By Ralphie in forum Newbie
    Last Post: 03-20-2007, 10:22 PM
  3. First install of car pc working :)
    By optip in forum General Hardware Discussion
    Last Post: 09-09-2006, 07:13 PM
  4. Attention Newbies! A FAQ to the FAQs
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-15-2006, 11:17 PM
