Results 1 to 2 of 2
Thread: noise / interference issues
    Jul 2007
    Wellington, New Zealand
    Hi all,
    I know this has been covered a lot and i've been looking through the previous posts on this subject but i'm still having issues and just want to exhaust my options before turning to a ground loop isolator. This mainly because i'll eventually end up running a digital recording setup.
    my setup:
    head unit
    600w inverter
    So the sound is perfect until i plug my powerbook/laptop in to the stereo aux when its being powered powered by the inverter - I get a massive buzz/noise through the system With the inverter off its fine.
    I have tried grounded everything to the same point with no change. Have tried different aux cables - no change.
    So the only things i can think of at this point are:
    * the fact that the inverter approximates a sine wave (instead of the pure sine wave)
    * maybe i need to customly ground the powerbook (?? - e.g run a cable from the metal chassis inside the laptop [but i've never had any interefence issues before])
    * kill or replace the fan in the inverter (seems to be the source of interference really) (this is my preferred option at this stage)
    * just go out and grab a ground loop isolator
    Any ideas?!!? words of wisdom much appreciated!
    Mar 2004
    Little Elm, Texas
    Have you seen this FAQ perchance?
    however, I will suggest you replace your inverter with a product that was designed specifically for the CarPC market - a DC-DC PSU.
    10:1 it will immediately remove the noise issue you're running into.
    Jan Bennett
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. Enhance ENP-2320 noise issues
    By strohj in forum Power Supplies
    Last Post: 01-08-2006, 07:50 PM
  3. Another Static and Hard Drive Noise Problem
    By dpom in forum General Hardware Discussion
    Last Post: 11-28-2005, 10:07 PM
  4. Yet another noise thread: Weird problems
    By Knutti in forum Car Audio
    Last Post: 09-17-2004, 12:56 PM
  5. Damn Noise
    By Freeman in forum General Hardware Discussion
    Last Post: 03-20-2004, 01:37 AM
