Results 1 to 10 of 15
Thread: OPUS 120W -1 green flashing led
    Newbie maddop's Avatar
    Oct 2005
    Liverpool
    Hi All,
    I have an OPUS 120W power supply with VIA EPIA SP13000 Nehemiah Mainboard.
    My car is BMW 320D with standard kit.
    My OPUS is wired using 8AWG wire, 2x +ve direct to battery and 2x -ve direct to battery.
    I have 12v ignition direct to OPUS.
    I am getting 1 green flashing LED which indicates the battery is below expected voltage. I have used the factory jumper settings as my battery should fall into this category.
    What am I doing wrong?
    I purchased it from linitx and have emailed both them and also OPUS directly for some tech support.
    I have previously had a carpc but was using the carnetix psu and this was working fine.
    PLEASE HELP SOMEONE....
    Thanks in advance,
    Paul.
    BMW E46 (year 2000)
    CARPC installed and working!!
    Jul 2007
    is there not a resistor that you twist to up the voltage, is this with the car runniing or not?
    Oct 2005
    Liverpool
    It is when the car ignition is on or off.
    it doesnt matter.
    There is no resistor. Just the jumper to set the startup and shutdown voltage.
    BMW E46 (year 2000)
    Elsewhere
    Get a multimeter and measure the voltage on your +12v line.
    You also didn't mention what you used to wire to the ACC line. Did you wire the ACC line to an IGN-controlled 12v source?
    How about the Wiki?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    I think one flashing green light is just "standby", ie: no trigger from the ACC line. As mentioned before, use a multimeter to check your input voltages.
    Oct 2005
    Liverpool
    Hi,
    Late reply but i've just got back from holiday.
    I've finally checked the input voltage and its 12.35V direct from battery.
    I am still having the same problems. Any more ideas?
    Thanks in advance,
    Paul.
    BMW E46 (year 2000)
    Apr 2006
    As binary said, one flashing should be just the standby mode for the PSU...
    Does the unit start when you turn ACC on?
    Oct 2005
    Liverpool
    I dont get any response other than the green flashing light.
    No fans on my mainboard turn or any other activity.
    Thanks,
    Paul.
    BMW E46 (year 2000)
    Apr 2006
    Did you check if you inverted +12 Bat and ACC?
    I had a similar problem, and it was related to the fact I had inverted the two (on my 150W which should be about the same...).
    I would also check the power button cable from the opus unit to the mainboard, maybe try it with a regular button and work from there.
    Mar 2007
    Winnipeg, MB, Canada
    Check to make sure the ACC on the Opus is connected to a switched ignition wire and not a constant 12 volts. You need to have the Opus 12v constant and ground connected for about 5 or 10 seconds before putting 12 volts to the ACC (turning on the ignition), or it will not power up.
  1. Opus 120 and MTSVO-SC, wiring questions
    By 01black_ac in forum Power Supplies
    Last Post: 03-22-2006, 08:36 PM
  2. Replies: 4
    Last Post: 01-17-2006, 12:07 PM
  3. Opus green wire "T"ing with soft power computer button
    By tangeray in forum Power Supplies
    Last Post: 12-06-2005, 11:32 PM
  4. Opus 90W Problem: No led flash, doesn't power up
    By Macklion in forum Power Supplies
    Last Post: 01-18-2005, 11:21 PM
  5. Replies: 1
    Last Post: 05-01-2004, 06:17 PM
