Results 1 to 6 of 6
Thread: m2 ATX, ground to chassis or battery?
    Mar 2007
    of the 3 main power inputs, for the negative battery marked input, can I ground to chassis or is it better to hook up to negative battery?
    thanks
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Chassis.
    Elsewhere
    addendum:
    Bare metal on the chassis.
    How about the Wiki?
    Mar 2007
    thankyou.
    then why does the diagram call it the "negative battery -" input?
    just curious as to if they think one way is better. grounding to the chassis is easier anyways so I don't have to route another wire all the way to the battery.
    bye the way, does radio shack have the fuse taps so I can tap my acc. line to signal the m2 atx?
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by Snortonnorton View Post
    thankyou.
    Technically, the negative battery is attached to the chassis too...
    Radio Shack probably has the taps.
    Nov 2006
    Isle of Orkney. UK
    Only a guess but I would say that they use the term "negative battery" to simplify for non English native speakers. What "ground " or "chassis" is in anything other than English I haven't a clue
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 11:10 AM
  2. m2 atx
    By slantman in forum Power Supplies
    Last Post: 08-08-2007, 05:45 AM
  3. m1 atx is killing my battery on taxi mode
    By cass944 in forum Power Supplies
    Last Post: 11-23-2005, 10:54 AM
  4. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
