Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: DS-ATX : Just installed, not behaving correctly
    Apr 2006
    Dallas, Texas
    When I start the ignition, the power supply starts the motherboard for a second, then cuts power causing the fans to stops. They don't even get a rotation. The light on the power supply is a solid red and the motherboard is getting some power to it as the LAN adapter shows an orange light on the motherboard and the CDRW/DVD-Rom is blinking.
    I'm using an MB896 board from iBase. I believe this is the same or similar to the one Red GTI v6 is using.
    Any clues of what I should look for to help with this issue?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Try just powering the motherboard, no hdd, or dvdrom, nothing but the mobo. Sounds like the PSU is overloaded.
    Apr 2006
    Dallas, Texas
    I will definitly give that a shot. I only have the harddrive, dvd-rom, and a wireless card plugged into the mini-pci slot. This power supply should be able to handle that easily.
    Elsewhere
    You might also try powering the whole ball of wax with a standard-issue ATX power supply, just to make certian that everything is in working order.
    How about the Wiki?
    Apr 2006
    Dallas, Texas
    Yeah, that's sounds like a good plan too. It was working on the bench before I installed it.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    ok my bet is you are either not using a 4 PIN p4 cable and your mobo requires that..or you mobo has a reversed polarity turn on switch
    Apr 2006
    Dallas, Texas
    Definitly somthing good to check. My motherboard does not have the 4 pin plug on it and I have tried the power switch in both directions. But still good ideas!
    Apr 2006
    Dallas, Texas
    Here is an image of the motherboard.
    Apr 2006
    Greece
    r u sure that the 4pin thingy on the right of the ATX power connector is not the 4pin P4 connector!!!??? because i am 99.9% it is...
    Dec 2006
    There is a P4 4pin connector there!
    Its touching the main PSU connector
  1. Replies: 13
    Last Post: 07-19-2007, 02:57 PM
  2. LOG: Software installation and setup
    By d_sellers1 in forum Software & Software Development
    Last Post: 06-08-2006, 10:11 PM
  3. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
  4. FS: OPUS 90W DC-DC ATX PSU w/ upgrade Never installed
    By guitar333 in forum Classified Archive
    Last Post: 02-25-2004, 12:56 PM
