Results 1 to 10 of 17
Thread: M2 ATX installation trouble with ignition signal?
    Mar 2007
    I tried my m2 atx but can't boot up.
    When I test the fuse tap I'm using (radio fuse) it shows 12 volts when the car is NOT switched on. does this mean It's not sending an on signal to the m2 atx that car is on?
    the computer fans spin, but never seems to send a signal to the on/off switch.
    I tested the ignition key switch and it also shows 12 volts on a hot side when no key is turned and car is not on. Is this my problem?
    thankyou
    Mar 2007
    well I'm realizing that the ign signal wire from m2 atx should go to a source that is "zero" until key is turned. and since my mulitmeter says the fuse tapped line has 12 volts even when car is off, that must be my problem.
    so how do you guys tap into a 12 wire that is hot only when key is on? i'm going to have to splice wires from a cigarette lighter? (i have 3 in my frontier and some only work when car is on)
    surprised that being on the forum I never heard of how people wire this line. I only read how you wire the constant wire and the grounds.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Try tapping another fuse. What kind of vehicle do you have? This will help you get more detailed responses.
    There is usually an ACC fuse you can use.
    Nov 2006
    Isle of Orkney. UK
    You need a wire from the auxiliary position of the switch.
    In other words find a wire to anything that only works when the ignition is on and tap into that
    Elsewhere
    Quote Originally Posted by brodgar View Post
    Suggestions:
    Radio wiring harness
    Cigarette lighter
    How about the Wiki?
    Mar 2007
    well, it doesn't look good. I found a good place for the ign. signal wire. I tested it and only has juice when car is on. the power supply turns on the fans when car starts, but nothing ever posts.
    motheboard works fine on regular atx powesupply.
    the board is a Asus a7n8x deluxe socket A462.
    My M2 ATX is a 90 watt, but I'm only running a hardrive, and 2 fans plus cpu fan. I even unplugged the 2 big fans to see if more juice allowance would help. but the computer would still not post.
    How can m2 ATX's run Pentium 4's if it can't run my old AMD?
    anyone ever use this motherboard with a m2 atx?
    I'm going to try other jumper settings on the m2 atx. (i only tried the suggested one.)
    Jun 2003
    Fairfax, VA
    Maybe the polarity of the power switch is flipped.
    Mar 2007
    I think I tried turning that, I will check again.
    but the mother board fans did come on only when I turned my car on. so wouldn't that mean the switch is working?
    thanks for the help everyone.
    i'm getting pretty close to just buying a mac mini and an inverter.. LOL
    no, don't have the money.
    Mar 2007
    well, Stupid *** me.
    I went back to check on wattage calculators and it seems i have the WORST power consumer. The socket A amd is 60 watts alone. (over 1000 mhz) plus the Asus A7n8x deluxe motherboard is massive front side bus and extras on it.
    I tried taking a stick of ram out and it still could'nt boot up.
    should I get 160 watt m2 atx or should I get a different motherboard that uses less power?
    Elsewhere
    And this, ladies and gentlemen is why it is recommended to plan your setup thoroughly before purchasing any hardware.
    Really, at this point, you have two choices: NEw motherboard/CPU or new PSU. You realize that.
    It's a matter of determining which one is going to be more cost-effective for you.
    How about the Wiki?
  1. M2-ATX Problem - Fan runs but does not boot !
    By Autonator in forum Power Supplies
    Last Post: 11-14-2006, 06:22 AM
  2. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 12:24 PM
  3. Replies: 7
    Last Post: 03-09-2006, 06:54 PM
  4. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  5. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
