Hi, I had a couple of questions I was hoping someone could help me with. I have the P1900 and the CNX-P5V. In the installation manual for the CNX-P5V
it says that I need to turn on the DLYON on the secondary output in order for the CNX-P5V to work. Could I use the PRI OUT instead?
Currently I'm using the ACPI relay to turn my laptop on and it works just fine, however I have to turn my monitor on manually every time I start my car. Could I connect the on/off button of the monitor to the ACPI relay as well? Would it work for both, the laptop and the monitor? The reason I'm asking this is because if I was to use the ACPI relay for both, I would have to use the PRI OUT because the DLYON would turn the power to the monitor on after the ACPI had already started the monitor and that just wouldn't work. Any help would be appreciated. Thanks
