Results 1 to 4 of 4
Thread: Newbie Carnetix p2140 - SX260 Question
    Jan 2004
    Sorry for the longish newbie post.
    But after reading the threads on here I decided to go with a Dell SX260 and the Carnetix p2140 setup instead of the Laptop that I had handy.
    I've read all the threads on this but cannot get the following setup to work:
    p2140 Input
    2x Red - Positive Live via a fuse
    2x Black - Ground
    Yellow - Ignition
    p2140 Output
    Pri Red - Red & Brown cables on SX260 lead (12v)
    Pri Black - Black & White cables on SX260 lead (Ground)
    Sec Red - Red on Touchscreen (12v)
    Sec Black - Black on Touchscreen (Ground )
    Now when I connect the input and output connectors to the p2140, I dont get any led display. So I have checked the connections with a Voltage Test Light and found that the two input reds were fine, the connection between the p2140 and SX260 lead had no power. However when I tested that connection it seemed to make a circuit and the led display flashed.
    Anyone have any ideas what is wrong.
    Cheers
    DAn
    Jan 2004
    Any ideas anyone?
    Jan 2004
    Anyone?
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Quote Originally Posted by dw_uk2000 View Post
    Anyone?
    Would really need more detail on the connections. a Simple diagram made in MS Visio, MS paint or any program could help elaborate. Or pictures.
    You say you're getting no red led power inside the carnetix? If so somethings off with your jumpers.
    Does your sx260 run at 12v? How many amps does it draw (look at the power brick for the sx260)
    You could be attempting drawing too much power at 12v thus overloading it. The lower the voltage the more power(amperage) hungry devices tend to be when talking about complicated electronics.
    What is the Dell SX260? Is it a PC or laptop, if its a PC with it's own powersupply then connecting the outputs from the 2140 is completely wrong. If it is a desktop IE an optiplex then it expects 110v AC voltage not DC.
    The Carnetix 2140 isn't properly suited to power a normal computer as they require multiple voltages via a mATX power connector on the motherboard.(12v+, 5v+, 3.3v+, -12v, -3.3v and potentially more) Then again if the SX260 is a special micro based setup it might accept dc via a wallwart. But I doubt it.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  1. Carnetix P2140 & Dell sx260/270
    By BasicEvil in forum Power Supplies
    Last Post: 12-03-2007, 04:06 PM
  2. Newbie with a Roadrunner Config Question
    By jay2000 in forum Newbie
    Last Post: 07-16-2007, 01:24 AM
  3. Carnetix P2140 Standby Mode Question
    By ThunderStick in forum Power Supplies
    Last Post: 07-04-2007, 10:19 PM
  4. Newbie question
    By jaydm in forum General Hardware Discussion
    Last Post: 10-21-2006, 11:07 AM
  5. Complete Newbie Question.
    By DomesticImport in forum Newbie
    Last Post: 07-07-2005, 07:24 PM
