Results 1 to 6 of 6
Thread: Opus Dead??????
    Feb 2006
    Unhappy Opus Dead??????
    Hey everyone. ok so i took my car computer out for about a week, it was just sitting in my room while i went on vacation and the car was just parked outside. I came back and first thing i did was put my car computer back in. hooked it all up and when it powers on, it stays on for two seconds, fans spin, case lights are on, then turns off and repeats this process over and over again. i have tried everything, checked all the wiring, case connections, unplugged and replugged the opus to everything. i dont know what is wrong. HELP PLEASE!!! just some info, i have the opus 150 powering one SATA HD, DVDRW drive and my screen, everything worked great without a flaw before for months.
    thanks in advance to anyone who helps!! I hope its not hte opus
    Mar 2006
    Colorado, but Canadian!
    You have the battery in while plugging in and taking it out? See any magic blue electrical sparks? If so, then probably. Always remove 1 terminal from the battery. It takes a second and it prevents this.
    Other than that if nothing has changed, perhaps your battery is too low. Do you have a deep cycle or regular crap walmart battery? I just yesterday got back from vacation and put my deep cycle battery back in. It took a second to crank it instead of the normal turn and vroom. It was turn crank crank crank vroom. And that was only a week and a bit.
    So drive around a while, recharge it to full and see if it helps.
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2006
    the battery was purchased in the past month ish and it wasnt the cheap kind cuz i knew about the computer being in there i got a $100 battery THE WORKS haha. there arent any sparks at all. all the wiring is secure and nicley electrical taped.
    Mar 2006
    Quote Originally Posted by avix View Post
    By cheap I did not mean money. I meant cheap as in crap.
    $100 in walmart buys you something different than $100 in gucci.
    The battery you bought, is it a deep cycle. Commonly called Yellow Top or Red Top which is the same as calling tissue paper Kleenex. Also known as a marine battery.
    Feb 2006
    yes it is. i bought it at autozone its definatley not the battery itself
    Feb 2006
    any ideas anyone? does opus come with a good warrenty? do you think it can be swapped out?
  1. Custom Controller for OPUS 120W
    By walttoinfiniti in forum Power Supplies
    Last Post: 06-14-2007, 07:09 PM
  2. OPUS 150 voltage tolerances
    By Mr.Mp3 in forum Power Supplies
    Last Post: 06-03-2006, 09:42 PM
  3. Wiring two OPUS to one computer system
    By lookinco in forum Power Supplies
    Last Post: 09-07-2004, 12:23 PM
  4. Battery dead in car. Opus?
    By Chairboy in forum Power Supplies
    Last Post: 05-13-2004, 01:06 AM
  5. Think this Opus 90W is dead?
    By ZenerDiode in forum Power Supplies
    Last Post: 04-26-2004, 03:05 PM
