Results 1 to 6 of 6
Thread: M2-ATX and Jetway 1.2GHz Fanless - RESOLVED!!!
    May 2006
    Ottawa, ON
    Hi All,
    I just recently got my carputer equipment i'm pretty excited. I have tested the M2 ATX and things seem to be working fine, I get power and the start up/shutdown timers work. I've plugged it into my Motherboard and connected the power button pins to my Mobo as shows in the manuals and the Mobo does receive power.
    The problem is that I get No VGA signal, no Beeps and the Mobo doesn't post. I've searched on the forums and found that there are some people modding their M2-ATX supplies... but I'm really kind of confused with all the mods they need to do. I'm just hoping I can get some clarity on this one since some of the posts date back to 2006 with the same issues.
    I've read about contacting Ituner about what can be done, but it's also said that the mods were supposed to be incorporated into the new model M2 ATX as of Jan 15 2007. So I'm posting because I'm unsure whether this has to do with the timing issues that the M2-ATX has sending the power on Pulse or whether or not there's something wrong with the Motherboard.
    That said, I did get it to beep once this morning after disconnecting everything and leaving it over night. When I reconnected everything it gave me a RAM not detected beep. However when I put the RAM back in it started acting the way I described above, no beeps, no vga, no post.
    Thanks for any help on this matter, I'm looking forward to getting this all set up!!!
    - Andrew -
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    its not the power supply. I might be your memory. As i know the m2-atx only time it need modding is when you use a lv-677. trust me i started that thread. i callled iturner up and spoke with a guy there and modded a couple of my m2-atx. check memory it could be your problem.
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    have you tried your MB on a normal power supply?
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    May 2006
    Ottawa, ON
    Hey thanks for the quick replies , acutally I haven't tried with just the ATX power supply as I have no way of using the power button pins on the mobo to turn on the computer (unless I can just short them together), however I have gotten the Mobo to beep (one long beep every few seconds with the ram stick in) a few more times when I set the M2-ATX to mode 0 (normal PSU mode) So I'll see if it's just the RAM. I'm gonna try to take it to a Comptuer store tonight to see if they can test the mobo for me using a real PSU.
    Thanks for the suggestions I'll let you know how each of these tests go,
    - Andrew -
    Jan 2005
    Scotland
    you can just touch the pins together to test it if you want.
    May 2006
    Ottawa, ON
    Hey Guys!
    Thanks for helping me solve this one! I got it working it was a faulty RAM module. Woot! off to the software install!!!
    Thanks again guys!
    - Andrew -
  1. Jetway mobo's
    By kamikaze2112 in forum General Hardware Discussion
    Last Post: 04-04-2008, 10:05 AM
  2. Fix for M2-ATX and Jetway!
    By andrewb in forum Power Supplies
    Last Post: 09-16-2007, 05:28 PM
  3. Jetway 7F2WE-1G5-OC motherboard problem with bios
    By sajeev in forum General Hardware Discussion
    Last Post: 03-15-2007, 10:40 AM
