Results 1 to 10 of 14
Thread: AOpenPC - Find 12V Rails?
    Newbie PatInTheHat's Avatar
    Jun 2007
    I purchased a MP945D which uses a 945GM motherboard. I recently realized I am going to need one 12V rail and quite possibly two. Unfortunatly I took my case apart and I can't find a single rail in there at all.
    Anyone have any suggestions for me?
    *Not sure if this is the appropriate forum, please move if nessesary*
    Registered User
    I don't think there's is a 12v rail you can tap into on that pc.
    How do you plan to power the pc? If you decide to go with a carnetix psu that you can get the 12v from carnetix secondary output.
    Jun 2007
    I am going with a Carnetix PSU unfortunatly that 12V is already spoken for. I need to power my LCD, my XM satellite and one more to power a circuit board I am installing.
    Is there another way I can power these other devices?
    Jun 2007
    Update with some pics. The only connector I can even see available is the one circled in green. I have no idea what this is, can anyone identify? Feel free to point out anything else that might be useful power wise:
    Mar 2006
    Colorado, but Canadian!
    That's not a power connection. If there were a mini-PCI card in there I would say it was for a wireless antenna (bluetooth or wifi). But no card, so I dunno, but it is not power.
    Also your screen should have come with an egg. That is a 12v regulator.
    Depending on how much power you need, you may be able to just buy a spare egg from Armen at digitalww and use that.
    For XM I doubt it draws that much power. So an egg might work for it. I cannot speak for the circuit board because I dont know what it is... but since the screen is meant to be powered from an egg, use the egg on the screen and the carnetix output for the board
    1.9in x 2.9in -- 47mm x 73mm
    Elsewhere
    Pat:
    I replied to your PM before seeing this thread...
    As such, I hadn't seen the photos. It appears that there may not be a standard-issue HDD conenctor from which you could draw 12v. sorry about that.
    I like ToasterBoy's idea. Get a spare regulator egg for the Lilliput and use the Carnetix 12v for the XM. I also think that you can probably use both the screen and the XM from teh Carnetix 12v, but I'd double-check the power requirement for the XM unit before attempting that.
    Either way, you've got some options.
    How about the Wiki?
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    Quote Originally Posted by 2k1Toaster View Post
    That is a wireless card, it is a mini-PCI. You can see where it's attached to the antenna going out the back of the computer.
    But correct, not a power cord. It's just the external antenna cord.
    Mar 2006
    Quote Originally Posted by Phatsacks View Post
    yes the port is mini-PCI but there is no card in the slot. So that is why I wondered.
    May 2007
    Springfield, Va
    Actually I was wrong.
    The cord he indicated in the first picture, is different from the external antenna cord.
    The reason you don't see the card is that it's attached to the HD and CD which are fastented to the top of the case. When you close the case, it gets pushed in the slot.
    I'd have to open up my case to see what the cable actually is.
    Jun 2007
    Thanks guys. I'll look into a regulator. The XM unit is the mp3car one:
    http://store.mp3car.com/Mp3Car_USB_a..._p/sat-007.htm
    The circuit I need to power is to control open/tilt functions for my screen housing.
  1. 12V USB Hub, Help!
    By spoonraker in forum General MP3Car Discussion
    Last Post: 10-30-2008, 12:42 PM
  2. Xbox 360 in my truck, 12v and all. Need oppinions!
    By viper24 in forum Power Supplies
    Last Post: 03-02-2006, 08:53 PM
  3. How-To: Modifying the PW200
    By evandude in forum Power Supplies
    Last Post: 08-18-2005, 07:45 AM
  4. Opus 150 problem (overloading rails)
    By Craig W in forum Power Supplies
    Last Post: 07-18-2005, 12:16 PM
  5. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 01:47 AM
