Results 1 to 7 of 7
Thread: pc using a lot of power when shut down
    May 2006
    Belgium
    Hi,
    i have a problem: when my pc is shutdown, it uses so much power, that it drains my battery.
    i measured it, and when i plug in the fuse from my pc, it uses 0.5A (6watt) when it's shut down...
    what can the problem be? I never had this before, it started a week ago...
    can it be that some usb devices keep using power when my pc is shut down or in standby (or hibernated)? can that be the problem? or is it something else? i recently connected my dvd drive via usb instead of ide (with an ide to usb convertor), but the power for that is comming from a regular molex, so there is no power on that when pc is off...
    Greetz
    Dj NRG
    _
    Mar 2004
    Little Elm, Texas
    Have you tried measuring the current draw after unplugging all USB devices?
    Jan Bennett
    May 2006
    Belgium
    not yet...
    battery was too empty
    will charge it tonight, and measure it tomorrow...
    i'll let you know what it says...
    Greetz
    Dj NRG
    Low Bitrate MibMib's Avatar
    Jan 2006
    KyrGyzstan
    i am interesting in it too. What type of power supply do you use ?
    400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
    Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
    May 2006
    Belgium
    opus 150 watt...
    Greetz
    Dj NRG
    May 2006
    Belgium
    ok, so i got to measure things...
    when my pc is shut down completly, and all usb devices are plugged out, my pc eats 1.2watt. when my usb cables are plugged in (steering wheel control, touchscreen, usb dvd drive (all 3 over a hub) and external soundcard), my pc eats about 4.8 watt!
    what sould a pc normally use when completly shut down? 'coz i think 1.2 watt is also quite much. and what should it use when in hibernation /standby? and can i change some setting (in bios or somewhere) to feed no power to my isb devices when pc in out (shut down, hibernated, standby)
    a lot of question, i know... hope to get the same amount of answers
    Greetz
    Dj NRG
    Dec 2006
    College Park MD USA
    Yes, at least in my BIOS, there's a setting to shut down USB in Standby (S3) mode.
    Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
  1. NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA
    By ichiban in forum Classified Archive
    Last Post: 07-21-2006, 01:00 PM
  2. How do i power pc in car?
    By ironic in forum Newbie
    Last Post: 08-28-2005, 03:12 PM
  3. Remote PC Power Switch
    By Terran in forum General Hardware Discussion
    Last Post: 01-06-2005, 09:13 PM
  4. Can't power LCD and PC at same time?
    By SBDJ in forum Power Supplies
    Last Post: 11-10-2004, 09:06 PM
  5. does the ITPS power supply fully shut down power to the PC?
    By bertybassett in forum Power Supplies
    Last Post: 01-29-2004, 11:26 AM
