Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: W3bMa5t3r's USB Power Modules
  1. #11
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    I haven't done any measurements on this yet, but I've had the I455 phone running 24/7 off the 2 port no data module. I've gone out to the car after 24 hours and had no noticeable affect on the battery, and I have a big motor to turn over. I'll be checking battery voltage levels later today and for the next 1-2 days as I'm letting the car sit (I'll prolly change the oil on Tuesday though, so I'll be cranking her back up then (well hopefully )).
  2. #12
    Apr 2006
    Ok, so the car has been sitting for 3 1/2 days with the cell phone running/charging off it. Just went out and checked the voltage on the car battery. It's sitting at 11.6vdc. So yeahhhh these modules are doing fine.
    I'm not sure if a GPS puck would use more or less power as I know cell phones can suck some serious juice(cell battery) when using the gps module and uploading data, but it seems so far, that it should do fine on daily/almost daily drivers.
  3. #13
    Dec 2006
    maine
    my laptop is one of the few that leaves 5V powered on when its in suspend to ram.
    The battery isnt one of the most powerful ones ever, my laptop pulling 22-25 WHR from it, I get anywhere from 2-3 hours.
    as a test, I left the gps plugged in and running off the machine while the laptop was in suspend. (again, my laptop leaves USB powered up in suspend...)
    The gps remained locked on for about 2 days before the laptop battery was shot.
    They pull a noticeable amount of power, but I'd imagine a car battery has a heck of alot more go-juice than this laptop battery.
    64 WHR battery, unfortunately Its reporting 41% wear now...during the test it was less than 20.
  4. #14
  5. #15
    Constant Bitrate gokee2's Avatar
    Feb 2006
    B.More, MD
    Hey Steve,
    Here is my question: How are your great modules any different from say a regular USB Male to Female extension cable? I guess where I'm lost is that if you do connect say the data transfer module to your mobo USB and you run a USB powered HUB into your module you will have enough juice to power more than one "power" hungry device like an external DVD drive and say maybe an external HDD?
  6. #16
    Apr 2006
    Well with USB standards giving each port a max of 500mA. For each device plugged into that port, you're dropping the available power.
    Code:
    [] - 500ma (1)
     L___[] - 500ma (2)
          L___[] - 500ma (3)
    That's how power is supplied. Now if I plug a device into hub 2 that pulls 200mA, it leaves 300mA for the other 2 ports, because port 1 can not (not supposed to) exceed 500mA. So if you plug into 3 that requires 400mA... something is going to be hurting.
    My module supplies(makes available) a total of 1500mA. Making it perfect for power hungry devices, even more than one . The other thing is my modules can be set to be always powered on, for items like cell phones, or gps pucks that you would like to keep on...
    Cheers
  7. #17
    pim
    pim is offline
    Mar 2006
    The Hague, the Netherlands
    It would even be better if it would use the host's USB 5v to switch on and off, rather than the car's switched 12v.
    This way, your connected devices will still be connected if your car pc shuts down, usually after you turn off ignition. Disconnecting your devices before shutting down may cause havoc.
    Pim
  8. #18
    Feb 2006
    B.More, MD
    Nice, Very nice. Great Job You think I could pick up one of the data pass-thru modules at the next car meet?
    ps: check this link out http://www.aximsite.com/boards/x50-x...-must-see.html
    Can you make one of those Steve or teach me how to. LOL?
  9. #19
    Apr 2006
    Quote Originally Posted by gokee2 View Post
    Thanks, and sure. I'll try to have a few of each w/ me.
    Dang... I haven't had a chance to look over it much since I'm at work, but it looks pretty sweet
  10. #20
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by W3bMa5t3r View Post
    The modules supply 1.5mA of power, USB specs are 500mA per port, so this should do fine.
    Both modules will supply up to 1.5mA total. And yes, the specs for USB ports is 500mA per port. I swear I wrote that above
    Perhaps you could clarify. 1.5mA (which seems unlikely, but you wrote it twice like that), or 1500mA? I doubted it the first time you wrote it, was just plain confused the second time, and the third time it seemed far more reasonable.
  1. Bytecc BT-200 USB 2.0 to IDE Adapter power?
    By hauler34 in forum Input Devices
    Last Post: 11-07-2006, 02:02 PM
  2. Another USB standby idea: splice wire and use a relay?..need help
    By S4Per in forum General Hardware Discussion
    Last Post: 11-04-2006, 11:12 AM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. USB power issues - opinions please
    By zaxxon in forum Power Supplies
    Last Post: 07-20-2005, 11:03 PM
  5. USB power & touchscreen issues...
    By Ren77 in forum General Hardware Discussion
    Last Post: 12-11-2003, 05:56 PM
