Each module supplies up to 1.5A (1500mA).
1500mA for the one port with data pass through, or 1500mA shared for the two port, no data pass through.
do i have to use this if i am using a power usb hub. I have power connected to the hub so it would give enough power to all my device. Only thing i am using it for is my external 2.5 usb hd. Just a simple question.
Hey Steve,
If I connect a non powered usb hub to your data capable usb module, will that usb hub posess the 1.5A power rating to effectively distribute to other connected usb accessories?
Never did post the updated pics here. I ended up only making (other than for my personal use) the 1 port with data pass-through. Pics below. More info Here.
Hey guys. Let me resurrect this one...
I want to make sure I got this right.
Say I have a regular ol' USB hub (non powered) that I ran from my trunk pc to my glove box..
Normally, in order to power it for "heavier" devices, I would have to plug in an AC adapter into an inverter and power the hub.
My question is...
with the device from this thread, can I connect it (w3bmaster's device) to the car's power then plug its USB cable into the hub... thus feeding power into the hub?
Therefore eliminating the need to use the hub's AC adapter?
Or am I way off base?
Thanks for the help!
