Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Am I about to make a mistake? Powering Carnetix
  1. #21
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    I'll second www.knukonceptz.com. Just got my 4 gauge wire and other items and installed them this morning. I like the Kompression set-up they have. Anyway, if you can draw up a diagram of how you have things set-up I'm sure we can come up with some suggestions. On a single circuit (from the carnetix to your LCD) your fuse needs to be less than the rating of the smallest wire, so that the fuse will pop before that wire burns up from too much current. I would do one 5 amp fuse at the carnetix to lcd power wire right on the carnetix output wire and verify the wire you use can handle more than 5 amps.
    This is contrary to having a fuse every time you change gauge of wire. However, if a 5 amp fuse is connected to a circuit that has 12 then 10 then 14 then xxx gauge, anything that will handle more than 5 amps it will be OK. As long as the fuse will pop before any of the wire in the circuit burns up....
    Existing circuits like ACC are probably already fused...however check the fuse rating and compare to the wire you are using. If in doubt, fuse it. Inline fuse are cheap and easy to install... I just use the walmart inline fuse holders that take the automotive blade fuses.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  2. #22
    Oct 2006
    small town nebraska
    Forgot to ask, Where is that 15amp fuse located? You should have a fuse very close to the battery for the 8 gauge...so if the 8 gauge wire shorts out the whole wire goes dead past the fuse.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. Fiberglass and MDF sub enclosure walkthrough
    By monkeyracer in forum Fabrication
    Last Post: 05-19-2008, 02:55 PM
  2. Replies: 7
    Last Post: 01-24-2007, 09:31 AM
  3. Advice on Powering my System
    By st_claire in forum Power Supplies
    Last Post: 08-15-2005, 02:15 PM
  4. Carnetix P1900 (brand New Brought By Mistake)
    By rockyfozz in forum Classified Archive
    Last Post: 08-14-2005, 05:34 PM
  5. STUPID mistake I made - M1-ATX
    By sxt173 in forum Power Supplies
    Last Post: 02-20-2005, 11:33 PM
